Question about Hitachi CP-S225WT Multimedia Projector
Red square on the screen
When the projector is on even without any inputs going through the projector the screen is full of small red square all over. I replaced the lamp thinking that was the problem but it has not made any difference.
  • 2 more comments
  • pandb Sep 11, 2007
    I am not sure what you are saying here. so could I ask you to clarify.
    Also I actual have this unit mounted on the ceiling, upside down and have done for 4 years.
    So can you just clarify, do i pull it down and lie it flat normal way up, or upside down.
    thanks
    I cannot read the rest of your possible solution, can you resend.
    thanks
    guide2u, I cannot read the rest of your solution, so can you please resend your possible solution please.
    thanks
  • pandb Sep 23, 2007
    I have tried the laying of the screen flat and no luck. I am still getting vertical lines of red squares all over the screen.
    Is there something else I can do to try??
    Genius:
  • 1,139 Answers
This sounds like the LCD screen is not reacting properly. Try this lay the screen flat for a day. and then reinstall it and power it up. This has worked for me in the past.
Posted on Sep 10, 2007
  • Henry McKelvey
    Henry McKelvey Sep 11, 2007
    You are to lay it flat so that the lcd screen faces face down. The goal here is to allow the LCD elements to realign to an original position.
    Master:
    Sergeant:
  • 461 Answers
CHeck lens.. if not might be the liquid crystal panel give itself up...
Posted on Sep 09, 2007
When turning on the projector it shows the Optoma logo but will not boot to the home screen. Is there a way to reload the home screen software?
Depends on the model. If you saw a little fan, then there is a fan problem. There might be 3 fans. 2 square ones and one blower fan. Look for plugs with 3 wires(red/white/black or red/yellow/black). Those will lead to the fans from the mainboard. Occasionally the fan will spin but the tachometer lead will stop reporting the fan status and the projector shuts down. To being with I would clean out the projector fans and ducts thoroughly. That may clear up the issue. Otherwise there is a button press sequence to enable the service menu, but you cannot upload new firmware without special optoma software that isnt available. Another possibility is you have failing filter capacitors in the power supply. Be careful poking around under the hood. There is lethal high voltage possibly stored even when unplugged.
Nov 26, 2014 | Optoma ML300 Mobile LED Projector
I have a Sharp DT400 projector. I replaced the lamp, and the unit powers on, and displays a picture during warm up but only for a few seconds. The lamp indicator and power lights go back to red and unit...
If you try to turn on the projector a fourth time without replacing the lamp, the projector will not turn on.
Press ON, INPUT, UNDO, left arrow, ENTER and right arrow on the projector in order, and then press ON.
The lamp 0000H is displayed on the lower left of the screen.
Mar 26, 2011 | Sharp DT-400 Multimedia Projector
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
Display has red tint across entire screen. Could it be the bulb? If so, is that still available? Approximate cost?
two possible solutions----either a problem on the small circuit board that is connected to the RED picture tube OR the red screen control is turned up too high. These sets have a small square block with RED,Green, Blue screen controls(same place also has red, green, blue Focus controls) if you remove the speaker grill you will find an inspection plate made of masionite---the focus/screen block is visable behind it----get a flashlight and look carefully at the block---one row of 3 plastic shafts is Focus(don't touch those) the other 3 are Screens(you should see R, G, B marked) go to a blank video input(one with nothing attached) and turn the RED SCREEN CONTROL JUST SLIGHTLY TO THE LEFT UNTIL the red goes away.
Aug 06, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Apr 01, 2009 | Epson PowerLite® S4 LCD Projector
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
Dec 16, 2007 | Philips Televison & Video
Connect my fujitsu siemens v3515 to a nobo s-17e projector
hi
hold down the blue lettered function key "fn" located 2nd left on bottom row....the press the function key F3 / F4 / F5 / F6 whichever one has the small icon that looks like a square/rectangle....it toggles in3 positions so if it dosent work first time press the same keys again...make sure your projector vga cable is connected to the correct vga input socket and select the input device on the projector to computer and not video
Nov 02, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Convergence problem
We need a better description of what you mean by shadowing. However I am assuming: 1. You mean it ''bleeds'' off to the right when you have something with a hard red/blue drive. 2. When you turn the contrast and color down a bit it gets better. unfortunatly I cannot tell you how to fix convergence, but I can think of some other possibilities. In this case the red/blue emmision of the crt is dying off and going into saturation when driven hard. To fix, replace with a new picture tube/crt. In some cases you can get a little more life out of that tube (with a watchable picture) by having the screen, focus, cathode bias, and drives slightly readjusted. It will take someone with experience in doing these adjustments on a weak tube to get it looking as good as possible. Given the construction of the cathodes (guns) in that crt, only a very low level crt reactivate should be tried on it. The hard rejuv most crt testers give is highly likley to completely destroy the cathode on that crt.
Mar 22, 2006 | Toshiba 55H70 55" Rear Projection...
Hitachi CP-S225WT Multimedia Projector Logo
69 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
