Question about Canon PIXMA MP780 All-In-One InkJet Printer
Makes a loud clicking noise and reads scanner error.
When I turn the machine on,it makes a loud clicking noise and reads scanner error. Alarm button is flashing. Then it reads "Load paper, press OK" It alternates with the two messages. By the way, there is plenty of paper.
  • 1 more comment
  • thedread Jan 07, 2008
    same here
  • Anonymous Jan 24, 2008
    1. I have the same problem with the pixma mp780
    2. It reads "scanner error"
    3. It makes the loud clicking noise
    4. it shows the printer with the lid open, showing the chain below the glass
    5. nothing prints from the scanner
    Thank you, Bridget [email protected]
  • Anonymous Mar 18, 2014
    When copying the paper will not feed although the machine makes the right noises. An error message says that it is out of paper, to load some and press ok.I have run the print head alignment program and the 2 sheets of paper fed through ok. It still will not copy. Can you help?
I had this exact problem. This printer was given to me, so I didn't have the instructions. I'm pretty sure I damaged it when I tried to open it to change the ink. I didn't realize there was a lever. After I got it open, I had trouble closing it, but eventually I got it to sit down flat. It was after this that the scanning function ceased to work as described by others.
I searched online to find a solution, but was hesitant to buy a repair manual. I read about someone else who took the unit apart. His experience was really a help as he knew just what part to take off. You need to remove the gray panel on the right side of the unit (as you are facing the front). This is the side with the USB port.
There are only three screws to remove. I used a flat head screw driver to gently pry the pieces apart. There are two places it snaps together on the bottom of the unit. I was able to get it apart without damaging anything. Once it's open, you will be able to see there are a few ribbons that connect the top of the unit to the circuit board in the base. For me, two of these had come loose. I simply slid them back in the slots where they seemed to belong and put the thing back together.
It was easier than I imagined and it worked! Good luck.
Posted on Mar 16, 2008
  • Mac Gordon Jul 23, 2012
    I spent the better part of a full day trying to diagnose and repair the same condition with my trusted MP780. Finally I came across these repair steps and as the saying goes, "the rest is history". The only thing is I had to remove (2) screws to get the cover off; not (3). Many thanks.
    Genius:
  • 1,198 Answers
This is what I found in a scanner-copier. The moving bar of the scanner has a flat tab that fits into a slot that has a very small light in it. That tells the bar to stop. When dust collects in the slot area, the light can't see the tab, and the bar bangs into the end, and the belt jumps and makes noise.. Blow out the dust.
Posted on Mar 28, 2008
  • 2,427 Answers
Here is the service manual for your printer
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
it has trouble shooting and step by step repair instructions
Posted on Dec 31, 2007
  • Rishi Roshan Ali Jan 07, 2008
    miss ? why did our rate me as inappiorate ? the service manual is a detailed manual with troubleshooting and how to fiax anything that could go wrong with your printer. ehat happend to your printer if you read the service manual is that the carriage motor is stuck. you would have found this in the manual and the steps necessary in taking the maching apart to fix the problem.
    If you wish to try something else first, the service manual would have suggested that you click START/PRINTER AND FAXES and double click on your printer, then cancel all pending jobs. restart your computer then your machine.
    I seriously doubth that what i said was inappiorate. If you still think it is please let me know why so that i can try to do better next time. Thank you kindly .
SOURCE:
This phone randomly makes a very loud alarm sound that continues until the "end call" button is pushed. How can I prevent this from happening??
Do you won more than one of these phones? Try pressing the intercom button? is that the same alarm noise?
Has any liquids spilt on any phones, or have they got wet, been in bathroom during showers?
Nov 18, 2014 | Uniden DECT15602 Cordless Phone
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Pro 94 Scanner - Loud Input Volume
that is built into the features of the scanner and can not be turned off
Sep 05, 2012 | Radio Shack Pro-94 Scanner
I have a Kenmore 385.16221301 sewing machine and it makes a loud noise at high speeds
it's possible that something is loose or worn slightly to make the noise
Feb 27, 2012 | Sewing Machines
My printer is a Canon Pixma MX340 it is showing a error Document in ADF Press [ok] but after pressing ok another error reads Close the feeder cover [ok] eject the document
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
Sep 04, 2010 | Canon PIXMA MX340 Wireless Office...
Scanner mechanism stuck, making loud clicking sound
I've just got this problem after a powercut, whilst it was not being used but on. If you have only had it a few months send it in warranty.
Think I will have to take this apart and see if the scanner cable/ribbon/drive belt is caught on something or been stretched too much and can be replaced at all.
Its like at one end its caught and wont move the scanning head being stuck somehow, caught on something (doubtful tho').
Apr 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson SX100 Scanner makes a loud clicking noise!
On the back of the Epson Perfection 1660 Photo there is a lever that shows a lock and a unlock by where you plug in the wire to the computer. It must be in the unlocked position otherwise it will make that loud clicking noise and not work. Hope this helps.
Apr 07, 2010 | Epson Office Equipment & Supplies
I have an HP LaserJet 3380 all in one. The carriage on the scanner does not return and when it gets to the end of its travel makes a loud clicking noise as if it was trying to return to its rest position....
This is a fairly common problem with this model.
HP does not supply individual component parts to repair this, and you will need to look at getting the whole Scanner assembly replaced.
Depending on what country you are in,
look for this part number...
Q2660-60143Good Luck!
Dec 08, 2009 | HP Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
1,111 people viewed this question
Clive
Clive
old marine
old marine
Ekse
