Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Replacing the lamp wd-62327
How do you get the new lamp plugged in to the plug inside the tv with such a short cord
    Genius:
  • 1,153 Answers
Did you get correct lamp:lamp part # 915P020010 ?
Posted on Sep 10, 2007
6ya staff
SOURCE:
New Mitsubishi tv lamp isn't plugging in to make connection
you have to make sure you get the plug on the lamp fitting sits right so it will go home to the other end. make sure its not broken or moved as it will not locate on to the other end when fitting.
Oct 05, 2013 | Mitsubishi WD-62327 62" Rear Projection...
I have a GE D52GW12 rear projection tv. It seems to just loose power and turn off at random times. I already tried different outlets to get it working again.I can get it back working if I wiggle the power...
The tv a/c power cord have internal damages short on the head of the a/c plug itself.This work job is pretty simple if u can do a basic soldering jobs and have tools like a soldering iron and a roll of solders.Look around in ur house for a table portable lamp u don't used anymore unsolders and take that portable lamp a/c power cord.It have very simular design and make of a power a/c cord.Take the tv aparts simplely just unsolder the old tv power a/c cord and replace it with a portable table lamp a/c power cord.Those stars srews on the tv are called Allan wrench screws,must a have a set of Allan wrench screws drivers to use take out this screws out of the tv.Some ealier DLP tvs set made by GE are using these Allan wrench screws,tries to make it much more difficult to take the tv aparts as GE they're trying not to allow tvs owner to take the tv aparts.Or have any friend to help u can do it,have a soldering iron,a rolls of solders,have basic soldering skills.A Allen wrench screws drivers set u can buy it anywhere in a hardware store.
Sep 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
We replaced the lamp in a tv mitsubishi wd-62327 now there is a orange flashing indicator light....now what?
if the set is now working,its just a matter of resetting the lamp-hour counter in the on-screen menus.be sure to clean any filters associated with the fan which cools the bulb,or your new lamp wont last long!
regards,steve
Jul 31, 2011 | Mitsubishi WD-62327 62" Rear Projection...
T.v.says lamp not working
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
Jun 30, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Will not come on. Purchased new power cord and the new cord works on another monitor exactly the same. It is not the cord. The cord seems a little loose when it is plugged in. There is no function at all...
You need to check the solder joints on the circuit board where the AC cord is plugged into, also need to check for bad caps with domed tops.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 25, 2011 | Star Logic 17" LCD Monitor
The tv came on then the screen went black but there was still sound for a sec. Now the green light keeps blinking and the tv won't turn
Unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim. With trim removed, at top of LCD panel remove the (2) PC ribbon wire clips with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the lamp socket part # QSOCFA003WJZZ by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it and the tv should work ok then.
Dec 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Refrigerator has electrical short causing GCI outlet breaker to pop. Is this an easy or cost prohibitive fix?
It is possible you have a short. However, the more likely cause is the simple fact the refrigerator is plugged into the GFI outlet. Try this first, take a heavy duty three prong extension cord, NOT a lamp extension cord, plug it into a non GFI outlet, and plug the fridge into the cord. Does it trip your house circuit breaker? If so, then you do have a short. You will need to call a local refrigerator repair company to find the source of the short, and only then will you know if its an easy or cost prohibitive fix. If it does not, and it likely wont, the problem is that a GFI outlet detects a fault to ground. Due to the humidity and moisture inside a refrigerator, and normal water drainage sometimes into the metal base of the refrigerator, it is not uncommon for water to contact metal points inside and outside a refrigerator. Since all / most metal points on a refrigerator are grounded to each other, if water contacts any of them, they can and will trip a GFI outlet breaker, because it is detecting a fault to ground.
Nov 09, 2010 | GALAXY Microsystems 63702 Top Freezer...
I have a CLT2054 and lost the power cord. I bought a new power cord but when I plug it in the light on cord goes out and TV wont come on. If I un plug cord light comes back on
You have short circuits inside the TV, the AC goes into shutdown when it senses too much current being draw. Post some pictures inside the TV if you can, wee need to look for short circuits, another thing, you bought new AC adapter with the same voltage and current rating, right?
http://s807.photobucket.com/home/budm/allalbums
Jun 29, 2010 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Monitor wont turn on
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 20, 2010 | ViewSonic VX2255 Monitor
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
