Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
TV powers on then shuts off
I turn the TV on, the screen is looks green with static, then turns off by itself. I have another model just like it for parts, is there something I can inerchange myself?
    Genius:
  • 1,139 Answers
Hello catapracht, It looks like you shutdown circuit is turning the TV off due to a problem in the HV section. What you are seen is possibly a green cathode short and some blooming occuring. These will caused increased anode voltage and trigger the shutdown circuit. At this point I would not suggest blind swapping of parts but rather you find a repair shop on FixYa.com, or find a shop close to you to have this problem dealt with. Because these are dangerous voltages you will be dealing with and without the training and knowledge of TV repair it would not be adviseable to do these repairs yourself. However you can be of assistance in have this information ready for the repair person. Thank you, I hope this helps. Shuttle83
Posted on Sep 07, 2007
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
TV has sound but no picture
It is possible one of the internal fuses blew out.
It could be a bad horizontal outut transistor.
It could be a bad secondary of the power supply went bad
And many other things.
If it's just a fuse, it won't cost much, but a lot of them do not look like you would expect a fuse to look like.It might be a little yellow, green, or gray rectangualar box shaped part. :D
Dec 16, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
TV shutting off by itself
The plasma panels operate on 170VDC and 60VDC, Sound like the 170VDC from the power supply is low or dropping low. You need a tech to look at it, the voltage sources are marked on the board and the adjustment is labeled. Typically a component such as a regulator or capacitor is leaking to cause the voltage to drop.
Al
Feb 03, 2008 | NEC 42VP4 42 in. EDTV-Ready Plasma...
TV will not come on
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
Jan 03, 2008 | RCA 32F531T 32" TV
Television
Sounds like its going into auto protect shutdown. Try holding the imputand menu bottons in together for 5 seconds and see if the green light blinks out a series of blinks. If so notice what they are, should be a 2 digit code if its going into shut down. If not its a power supply issue. Also you can look the boards over for evidence of CRT fluid leaking on the boards, I have seen this happen alot to the VS models it causes corrosion of the components and you will experience no start up condition like the one your describing.
Oct 04, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
