Question about Olympus Stylus 410 / ? 410 Digital Camera
Olympus Stylus 410
The 'up' arrow pad does not appear to be working. When using the 'right' arrow pad the menu for changing the settings pops up over the 'flash' symbol. I can change the photo settings eg Inside, Program Auto by the right arrow key but cannot from the up arrow key. Because of this I do not have access to the 'flash' menu. Can someone please help.
    Champion:
  • 217 Answers
Try to clean the pad using water damped cotton if you are techie, professional fix is needed if you're not.
Posted on Sep 08, 2007
SOURCE:
How do i turn flash off on my olympus stylus 410 camera
Press cursor-right repeatedly to cycle through the various flash modes. The one you want is the lightning bolt in a circle with a slash through it. For full details see the "Using the flash" section in the reference manual (beginning on page 72 in my copy). If you need a manual you may download a copy from here.
Dec 16, 2012 | Olympus Stylus 410 / ? 410 Digital Camera
My memory card on the Stylus 410 digital is full. I have downloaded all photos and would like to erase the entire memory card. How?
Do you have a manual? Here is a link to the manual:
Olympus Stylus 410 Manual
You have to navigate through the menu to get to the ALL ERASE or FORMAT selection.
MODE MENU>>>CARD>>>CARD SETUP>>>ALL ERASE or FOMAT
When you turn the camera ON and press OK, you will get the "first menu". Press the right arrow to enter the Mode Menu. Use the arrow keys to navigate to the above item. Once on ALL ERASE or FORMAT, press OK.
Also, here is a quick start guide:
Olympus 410 Quick Start Guide
Scroll down to Section 5 for instructions.
You can save the manuals to your hard drive for future use once opened.
Thanks for using Fixya.
Jun 21, 2010 | Olympus Stylus 410 / ? 410 Digital Camera
How do I set the time delay on my olympus stylus 410?
Press down-arrow repeatedly and select the timer (looks like a one-handed clock). Press the shutter button to take the picture. The control lamp lights for about ten seconds, blinks for two, then the camera takes the picture.
Refer to the section "Using the self-timer" in the Reference Manual.
Jun 11, 2010 | Olympus Stylus 410 / ? 410 Digital Camera
I have a stylus 410 when turned on it displays 'write protect'
The memory card is corrupted and the only way to remove the write protect is to format the memory card when it is in the camera. To format the memory card:
Press the green arrow button to go to review mode then press the Ok button
Press the right arrow button to go to Mode Menu
Press the down arrow button to go to the Card tab
Press the right arrow button to go to Card Setup
Press the right arrow button to go to Format option
Here you will see Format Yes or No
Press up arrow to go to Yes and press Ok
The camera will indicate Busy because it is clearing the write protect and erasing all images permanently from the card.
Once completed the card will be able to be used again.
Sep 23, 2008 | Olympus Cameras
Have a stylus 410 when i turn the camera on it displays 'write protect'?
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
No flash
It is a problem that has happened to 2 out of 2 of my Stylus 410's. Olympus will not reapir them unless they are under warrenty (or for $175). I filed with the BBB...we'll see if that helps. They really need to recall them. Good luck. =)
Aug 09, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Date and time
With the camera on, press the OK/MENU button. Use the arrow pad to select [MODE MENU]. Select the [SETUP] tab and press the right arrow. Select 'time icon' and press the right arrow. Select the date format and press the right arrow. Use up or down arrows to set each item and press the right arrow to move to the next item. Press the OK/MENU button when you have finished entering the date and time.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Date and time
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Date and time
With the camera on, press the OK/MENU button. Use the arrow pad to select [MODE MENU]. Select the [SETUP] tab and press the right arrow. Select ‘time icon' and press the right arrow. Select the date format and press the right arrow. Use up or down arrows to set each item and press the right arrow to move to the next item. Press the OK/MENU button when you have finished entering the date and time.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
All weather
The Olympus Stylus 410 Digital camera will not be damaged by water splashed onto it from any direction and can be used outside in adverse weather conditions such as snow or rain. The Stylus 410 Digital camera is all weather, not waterproof, and cannot be immersed in water. It is designed to operate at ambient temperature 32?-104?F and relative humidity of 30-90%.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Olympus Stylus 410 / ? 410 Digital Camera Logo
64 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
