Question about Texas Instruments TI-83 Plus Calculator
Fractions how do you change dec to fractions?
  • Anonymous Feb 29, 2008
    I need to know how to put in a fraction in the calculator
  • Anonymous Jul 02, 2008
    changing decimals to fractions. i press math, then 1, then enter and
    the decimal doesn't change to fraction
0.3 =
Posted on Oct 08, 2008
    Sniper:
  • 56 Answers
Okay so hit enter and get your answer then hit math and find the part that says frac and then hit enter twice
Posted on Jul 17, 2008
Press math and then 1 and then enter
Posted on Feb 11, 2008
3 Suggested Answers
SOURCE: fractions
a quart is one fourth of a gallon. Dan drank half a quart of milk. What fraction of a gallon did Dan drink
Posted on Sep 26, 2008
supportthe85
  • 35 Answers
SOURCE: fractions multiplied by fraction to get fraction
In the CATALOG there is a >Frac command that can be used with parentheses to multiply fractions.
(1/2)(1/3)>Frac
1/6
Posted on Nov 25, 2008
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
Fraction to degrees
There must be an error in the question. Could it be fraction to decimal?
The MATH menu has two options 1:>Frac, 2:>Dec.
The first entered on the command line after a fraction keeps the result in (reduced) fraction form. On a displayed result, it converts a decimal into a fraction.
The second 2:>DEC converts a fraction into a decimal number.
The latest OS (2.53MP and following) has a better handling for fractions.
Feb 27, 2012 | Texas Instruments TI-84 Plus Calculator
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
With the TI-84 Silver calc: what I really meant was - I want to input a set of mixed numbers (or just a regular set of one or more fractions e.g. 3/4 x 5/87) and either add, subtract, divide (or any...
Upgrade the OS of the calculator to the 2.53 MP (Math Print) version. As you can see on the following screen capture of the MODE setting, you can choose to use the CLASSIC option (the old way) or the MathPrint version.
You should notice that the Answers AUTO DEC or FRAC options allow you to configure the calculator to work in DECimal, FRACtions or AUTO (the calculator chooses whats is appropriate).
The n/d is for improper fractions and Un/d for mixed fractions.
Enjoy your new found freedom.
Here is the link to the new OS 2.53MP
Mar 25, 2010 | Texas Instruments TI-84 Plus Silver...
Converting decimals to fractions
Press MATH then 1 to select the >Frac command.
Mar 24, 2010 | Texas Instruments TI-84 Plus Silver...
Where is the fraction button
Press MATH to display the MATH menu. >Frac converts a decimal to a fraction, >Dec converts a fraction to a decimal.
Feb 08, 2010 | Texas Instruments TI-83+ Graphing...
Fractions
  1. Enter a numerator
  2. Press [/] for division
  3. Enter the denomoinator
  4. Press [MATH]
  5. Press [1:|=>Frac]
  6. Press [ENTER]
Keep in mind that the fraction that will be displayed will be a fraction reduced to its simplest form.
To convert a fraction into a decimal number Press [Math][2:|=>Dec].
Jan 27, 2010 | Texas Instruments TI-84 Plus Calculator
Answers in decimals
The calculator has two Input/Output modes, MthIO and LineIO. In MthIO the results are displayed as fractions or as radicals or a mixture of fractions and radicals. What it means, is that in MthIO the calculator does exact calculations. Radicals in denominators are gotten rid of by rationalization, fractions are reduced to the same denominators before addition or subtraction. Fractions are reduced to simplest form.
In LineIO all results are displayed as decimal numbers.
If a result is exact (fractions and radicals) it can be changed to decimal form by pressing the S To D key, the one above the DEL key.
MthIO is the default IO mode. To set it, press SHIFT MODE and select 1:MthIO. To set LineIO as the IO mode, press SHIFT MODE and select 2:LineIO
Jan 20, 2010 | Casio FX-115ES Scientific Calculator
Fractions on my texas tI-83
You get access the command by pressing [MATH][1: |->Frac].
If you want enter a fraction and keep it as a fraction (albeit a reduced one)
key in the number then the sequence [MATH][1: |->Frac]., then [ENTER].
Practice : 27/48 [MATH][1: |->Frac] [=] gives the reduced form 9/16.
While this fraction is still in [ANS] memory, you can press [MATH][2: |->Dec] [=] to get the decimal value 0.5625
Hope it helps.
Nov 01, 2009 | Texas Instruments TI-83 Plus Calculator
Can the TI-30X iiS convert decimals to fractions and if so how?
type the decimal you want to convert then press math button scroll down to were it says frac which means fraction then press enter on frac then press enter again to solve and to change it to a decimal type the fraction and press dec instead
Aug 23, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-83 Plus Calculator Logo
132 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
