Toshiba TV stereo drops out
I have an old Toshiba CF3273A TV. The stereo has started to drop out. It will drop in and out, but mostly out. Does anyone know a solution for fixing it?
    Genius:
  • 1,139 Answers
This might be a problem with the Audio output final stage where it goes from the Stereo decoder to the Audio amplifiers. This problem might not be something that you can fix if you do not have an electronics background. If you do not have a background in electronics I would suggest that you take this to a qualified electronics service technician. If you do have a background in electronics I would suggest that you get a schematic and begin testing around the stereo decoder and audio amplifiers.
Posted on Sep 11, 2007
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
How do i find the headphone jack on a toshiba lcd
Unfortunately, not all Toshiba TVs have a headphone jack, The 40E210U is one of those models. The above referenced model only has digital audio out. You would need a digital to analog audio converter and then RCA stereo to 3.5mm adapter to plug in most headphones.
You can always look on the back and side of your TV and look for a 3.5 mm port with a headphone symbol. If you have a different model, many Toshiba product manuals are available here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp . Click on Product Support and then use the drop-down menus to select your product. Then click on the GO! button and choose the User's Guide tab.
I wish that I had better news for you.
Dec 01, 2012 | Toshiba 40E210U 40 in. LCD TV
Last night I noticed the stereo was not illuminated and would not turn on. Today the car is completely dead, no power locks, no clicks on ignition. original stereo (not aftermarket) and this is first...
How old is the batttery? Most car batteries only last 4-5 years. I would check the date on the battery, and if it is around that old replace the battery first. If the battery voltage ever drops below 9 volts the computers can get a bit screwy.
Mar 15, 2011 | 2003 Volkswagen GTI
My toshiba laptop dropped the toshiba starting screen comes on but nothing eles.
reinstall to factory settings a friend of mine has to do this once a year worse case senerio your hdd is bad
May 20, 2010 | Computers & Internet
Sound drop with Shaw pvr box with hdmi. How do
This is a very common problem with no real solution. If your TV can be programmed to accept separate audio from HDMI video on the same input, you can feed the audio through standard RCA cables. Unfortunately most TV's do not allow this. Alternatively run them into a stereo receiver. Buying high end HDMI cables will not help. Most people I know with this issue have bit the bullet & just used component video instead. The difference in quality is minimal.
Apr 25, 2010 | Arris DCT6200 DTV Receiver
I need the codes for a toshiba tv
I have code listings for different devices. The codes listed for a Toshiba TV are:
0036, 0060, 0149, 0154 and 0156. Start with 0156 first. It your device only requires three digits, drop the 0. Hope this helps.
Oct 25, 2009 | One For All URC4220 Remote Control
CF3273A Toshiba Vertical height and linearity problem, looking for adjustments
I'm not real sure what year this set is. Most sets 5 years or newer have service menu adjustments. Unless someone went in and adjusted it to get it out of adjustment, adjusting is not going to do much good. I would be looking for bad capacitors in the vertical circuit or possibly the vertical output IC. These IC's tend to run pretty hot anyway so they are usually the problem along with leaky caps.
Oct 13, 2009 | Toshiba Televison & Video
TV Tuner failure after warm up
Check where the F connector is soldered inside the tuner circuitry, it may have a loose solder joint there. Also check the inside of the connector where the coax is attach, sometimes the inside conductors spreads and do not make good electrical contacts.
Good Luck.
Jan 21, 2008 | Toshiba CZ27V51 27" TV
Audio Problems
First for the Toshiba could the SAP (Second Audio Progam) be turned on this will somtimes cause the audio to drop. And are you using the onboard tuner or does this set conect to a cable box?
Then for the Panasonic the most common problem for your fault would be the convergance curcuits are shorted and need replacment, or some other componet may be loading down the set and forcing it in to shut down, Tv's will do this to prevent further damage
Jan 06, 2008 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
