Question about Bosch WFMC 3200 Front Load Washer
Long wash times
Timer resets. says you have 20 min. left then resets itself for another hour. washing towels takes approx two hours. sometimes after it resets it will say 50 min. left but will finish in 5 min.
  • ladywaiting Mar 10, 2008
    The wash cycle takes forever. I am having the same problem with towels as well. I bought the washer only a couple of years ago and can't do more than about 3 loads in a day. Hardly efficient! I would love to hear any other suggestions. I've tried using less soap and that seems to help sometimes.
I've had this problem, particularly with towels - it's quite annoying & not energy or water efficient at all. According to the manual, the unit has a sensor that senses if there is too much soap & it will continue to wash until the soap is removed. I found that this happened frequently on the "cotton" cycles & max spin. I've tried to make sure I use less soap, but I also use the perm-a-press cycle & the spin 1 down from max. Hope this helps
Posted on Sep 19, 2007
The hour cycle now takes only approx. 20 minutes
faulty timer or control board chip
is your machine listed on this site
http://www.venturamalta.com/washing/
May 11, 2016 | Blomberg Washing Machines
FOUR HOURS TO WASH TOWELS
That is not normal. Have the control circuit board tested for continuity. Either the cycle or timer section is out of wack and may need replacing.
Feb 27, 2014 | LG WM2487H Front Load Washer
Our LG WM2016CW Washing machine is having control problems. The timer is randomly resetting to odd times for example it may have only 20 minutes left and then the timer will reset to 3 hours and 59 min. We...
You must either be using the wrong stuff or adding too much detergent. Them washers have a built in program to fix a suds problem by changing the time and giving the program an opportunity to correct on it's own. By running a series of mini washes and whatnot to get the soap out of the washer. When too much soap is used it cause the motor to overheat. This is noted by the control and recognized as sudslock. Look on my DIY Youtube about page. I have a bunch of links to various blogs, manuals, and notes on what to check as well as a bunch of how to videos.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2013 | LG WM-2277HW Front Load Washer
F1247td is taking much longer than suggested wash time, over double in some cases
Sounds like a heater issue, holding up the timer due to not getting to temperature. Could also be timer, or even pressure switch. Difficult to diagnose without testing individual wash cycles.
May 17, 2012 | LG Washing Machines
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
I start the wash cycle timer reads 1:02 machine runs and timer counts down to 54 mins. then resets to 1:12 mins. which inturn adds approx. 18-20 mins to wash cycle why the reset??
I had a similar problem with ours and had a repair guy come out and look at it. He suggested running a couple of heavy bleach cycles through the machine. He said that sometimes if you use too much detergent (especially if you're not using the "High Efficiency" type of detergent) detergent builds up on a sensor in the machine and causes longer than necessary wash cycles. We actually ran 2 cycles of bleach and then a couple more with no bleach or detergent and the problem cleared up.
May 02, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
I have purchased a house with the single door dishwasher and it takes forever to wash - about two hours - what could be the problem?
Check your program settings. If wash quality is good, it's OK. Check your inlet water has sufficient pressure! Refer user manual
Apr 07, 2010 | Fisher and Paykel DS603SS Stainless Steel...
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Bosch WFMC 3200 Front Load Washer Logo
213 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
