The fusing lamp stays on at full power for 70.0 seconds while in the stand-by condition after warm-up is completed.
Possible Causes
fusing thermistor defective or dirty
Clean or change.
shut on the copier, press clear modes(yellow button), 107, and then hold down clear/stop (orange button). Enter 5810 then # key then 1 #. Turn off the main power then power back on to clear the SC condition.
If it does not solve it, the problem can be in board AC drive PCB2.
With the machine on, press clear modes(yellow button), 107, and then hold down clear/stop (red button). Enter 5810 then # key then 1 #. Turn off the main power then power back on. This code is a fuser lamp on condition. It should clear. If not reseat the fuser unit (gets hot), clear using above procedure and try again.
When I turn on the machine (NP6030) view teks ''Insert a control card'', but my machine is not have...
(More)
When I turn on the machine (NP6030) view teks ''Insert a control card'', but my machine is not have control card
Please how can I clear ''change the toner catridge'' display on AR-M276 Sharp Digital Copier after...
(More)
Please how can I clear ''change the toner catridge'' display on AR-M276 Sharp Digital Copier after refilling toner. peters
i need a repair man for my copy machine konica minolta di3010f because every time i print it come...
(More)
I NEED A REPAIR MAN FOR MY COPY MACHINE KONICA MINOLTA Di3010f BECAUSE EVERY TIME I PRINT IT COME DIRTY, can someone come to clean it for me and how much ?
My citizen ct-s300 printer is blinking an error message, 3 short blinks followed by one long. ...
(More)
My citizen ct-s300 printer is blinking an error message, 3 short blinks followed by one long. Someone else asked the same question and you said it was a bad main PCB and to send it in for repair. what is a bad main PCB, what's a PCB? The owners manual says that this error could mean either a "low voltage error" or a "abnormal CPU operation error." Any suggestions other than send it in for repair?
