Question about ViewSonic EA771 Monitor
Sound I have moved my computer and am not sure if i have unplugged something or if something is worng internally in the computer but i dont have any sound. I have a Viewsonic EA771
  • 8516 Nov 13, 2008
    i put up date on my computer after the up dates were put on i didn't have sound to listen to music and other sounds
    Problem Solver:
  • 7 Answers
Make sure your sound is connected,the wires to there correct location on computer.make sure monitor connections are correct and secure ,(tight)then reboot computer ,if know sound, then roll back sound drivers in device manager or re install sound drivers and reboot again,see if this correct's your sound problem
Posted on Sep 07, 2007
  • dwolfe55 Sep 07, 2007
    make sure you turned upand ON your volume on speakers also
    check your connections after you relocated your computer again , did your cat if you have one like me play with the wires and pulled one out or maybe loosen one of them ,were the kids fooling around back there , i dont have kids so I can cross that one off,HE HE !
Overload what do i press and hold to reset?
This is an old receiver. Probably something simple like leaving it unplugged would do.
Sep 06, 2014 | Technics Audio Players & Recorders
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
How to fix sound on my lg 42
Some simple things you may already have tried but I will list:
Unplug set for a while and then plug back and see if sound--when unplugged the set may reset.
In main menu make sure speakers are not switched off.
I doubt it is mute but if also using some type of box check that its volume is not all the way down.
If internal speakers put your ear right to them---hear low sound or a buzz or hum?
If using external speakers of any kind look at the hookup and switch to make sure internal/external is correctly selected
If NONE of these help you have an audio problem and should first contact LG (yes it takes time on the phone) to inquire if some common issue or a possible software upgrade is available for this.
Last: Some failure has occurred either in the audio circuit or something that feeds it.
Mar 22, 2012 | LG Televison & Video
Behringer No Input Signal
Mic level in the windows control might be muted or off. The sound functions are a control panel iterm Or in Macs it is a CDEV.
Also check to make sure the program has that input enabled as well.
and make sure you start out with fresh batteries, double check where you have things plugged in, so you are not plugged into the worng port plug on the computer
Feb 06, 2012 | Behringer Ucg102 Guitar To USB Interface
6 beep codes on startup
Mar 26, 2011 | Dell Dimension 1100 PC Desktop
The right speaker gives of a strange sound sounds like something is scratching something then it goes boom boom boom what's worng with it
The coil of the right speaker is already defective. Try using other speaker to verify the effect. If it's alright
then, just replace it.
Nov 06, 2009 | Logitech X-230 Computer Speakers
There is always static when using the cordless phone
make sure you dont have anything else around the base of your phone, that transmits an RF signal, like wireless routers, cell phones etc........
try replacing the cord that runs from the base of your phone, to the wall, and alsotry changing the channel on the phone if you can.
if none of this helps, unplug your phone from the line and the power, for about 30 minutes, and plug everything back up....wait for another 15 minutes or so (dont answer that phone), and then try to use it....take the battery out of the phone as well, when you unplug the deck.
if you still have the problem, after you have replaced the line too, then their is either a bad connection in the phone itself, or interference coming from something near the phone base, or the phone itself has an internal bad connection. meaning, move the base off by itself somewhere, awayt from other electronics if possible, replace the entire phone, or if that doesnt work, then call your phone company and have them come inspect / repair your line.
Sep 20, 2009 | Uniden Cordless Phone
One beep at startup - System does not bootup
You have what sounds like a RAM problem. Try known good RAM as a test. If it still fails, remove add on cards except video. Make sure that video card works. If it still fails to boot. Replace motherboard.
Jun 01, 2009 | E-Machines eMachines Desktop PC
My internal microphone doesn't work
If you are refering to the internal microphone on your computer then try this. Open up your windows sound recorder from Start - Program - Accesories - Entertainment. Hit the record button and talk or yell something if you would like. You should see recorded sound waves in the middle of your sound recorder. If you do not see the recorded waves this might mean that your microphone is turned off. To turn it on just Double click on the little speaker icon on your taskbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure the microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder and try to record again. If this does not work your internal microphone may not be working or your computer may not have come with a built in microphone.There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 17, 2009 | Audio Players & Recorders
Nikon D200 Auto Focus
It seems to be a problem with the internal working of the camera its self. I have requested a replacement fro my seller. Thank You Samuel
Apr 06, 2008 | Nikon Cameras
ViewSonic EA771 Monitor Logo
163 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
