Keyboards and Mice
Problem for Keyboards and Mice
Generic problem for all Keyboards and Mice
Mouse not recognized/ mouse port not wor...
By Playahaters on Sep 07, 2007
In device manager there is no Mouse shown... I bought new mouse. unpluged mouse, restarted compt. and reconnected and computer did not recognize mouse It also did not work. tried running virus scan (Avast/also Norton) No virus or worms. tried downloading Drivers from microsoft.. Still no working mouse... Cursor looks larger than normal and is stuck in the middle of screen. I also Updated my Microsoft windows updates. Also reinstalled all applications. Besides this computer is running fine. also all usb ports work as well just not Mouse Ps2 port... any help would be greatly appreciated...
Thanks in advance.
Same Problem
Apr 29, 2009
-   sucking idck-   Guest
Mar 06, 2009
-   I have a targus wireless notebook laser rechargeable mouse. My computer no longer recognizes it after it crashed unexpectedly for the first time. Other things don't work also, like my touch pad driver is said to be corrupt, and that I have to uninstall it to access my mouse settings. If I do, then I will not even be able to seach for a targus mouse driver. HELP!?!?-   Guest
Jul 26, 2008
-   can i run the Proxima MindPath IR50FX on Win XP?....-   Guest
Jun 08, 2008
-   my mouse is not working-   Guest
Apr 27, 2008
-   old-   Guest
Best Solution
posted on Mar 18, 2008
Helpful)
Monchi
Rank: Apprentice
Rating: 87%, 5 votes
I kept hold about 30 seconds the blue light button on the USB controller device and it worked!. I guess that's the way to sinchronize both the mouse and the USB controller of the mouse. Ramón.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Feb 15, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with my new optical mouse. I have a wireless USB mouse, but was tired of changing batteries on it and so I bought a new corded optical mouse that uses a PS2 port. The new mouse didn't work and I searched the entire web endlessly looking for a solution and almost giving up on it.
Any way here is the solution I found that fixed it for me:
1) Control Panel -> Systems -> Hardware -> Device Manager
2) In Device Manger window go to the View menu and select Show hidden devices
3) under Mice and other pointing devices, for me, there was a yellow question mark next to PS2 port. After I right click and uninstalled the PS2 port (with the yellow question mark next to it), my computer automatically shut down and rebooted. I was able to use my optical mouse in the PS2 port afterwards.
I got the solution from another site. It may or may not work for you.
Solution #3
posted on Sep 08, 2007
Somewhat Helpful)
paddygees
Rank: Wiz
Rating: 77%, 81 votes
Hi Sir
One suggestion that you could try is this first go into control panel if you have XP when it opens left click Appearance and themes when this box opens you can see a small box at the top left hand side in it you can see mouse pointers open this and you may find how toreset your mous defaults
Hope this helps
Paddy
Get back if it does not
Was this helpful?
Yes
No
Solution #4
posted on Nov 22, 2009
Not Rated)
lita27
Rank: Apprentice
Rating: 0%, 0 votes
ok my sister just told me her mouse in not working tried 2 other mouses still not working...any ideas
Was this helpful?
Yes
No
Solution #5
posted on Sep 25, 2009
Not Rated)
nowwink
Rank: Apprentice
Rating: 0%, 0 votes
I guess your optical mouse is Ps/2 type optical. I had the same problem.
I bet your new mouse is of 1000 dpi.
Then simply change the DPI settings of your screen:
right click on desktop
go to settings
Go to advanced settings.
Change the dpi setting
and restart the system.
Try this for different DPI settings and one will definitely work.
Hope this helps.
Was this helpful?
Yes
No
Solution #6
posted on Aug 08, 2009
Not Rated)
peach10
Rank: Apprentice
Rating: 0%, 0 votes
I moved the computer, which worked fine, and unplugged all cords. When I reassembled the computer and plugged the mouse cord into the port on the tower I realized that the holes for the prongs on the back are very battered. The mouse will not work on the computer now. Any solutions to get it to fit snug?
Was this helpful?
Yes
No
Popular Solutions for Keyboards and Mice
Questions and Unsolved Problems for Keyboards and Mice
Answer
Which Kensington trackball is better -- 64210B or 64213 or K64325? Which one has the least number... (More)
Answer
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your... (More)
Answer
My wireless 5000 works fine using the usb transmitter but I am unable to get the bluetooth search... (More)
Answer
mouse light doesn't stay on or function even with new battery
Answer
I need a driver and manual for model no. KB985W wireless keyboard/mouse
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 04, 2008
We moved and now the optical mouse is not recognized. Device manager says it's working. Have rebooted several times . Have installed Intelimouse software for my deskset 2.0A. Please help!!!!
Comment by Guest, posted on Feb 29, 2008
i put in the usb port its not moving when i click the mouse
Comment by keen6883, posted on Feb 26, 2008
my keyboard suddenly not working. PS/2 port doesnt function at all....
how to make this PS/2 keyboard KBS-720 working???
Comment by puppymommo, posted on Jan 08, 2008
Same product, simliar problem. Bought mouse GE wireless 98763, installed it and it worked fine. Yesterday I had the motherboard on the computer replaced and now I can't get the mouse to work properly. I have gone into control panel and tried to reset the mouse properties but it will not allow me to set the left button for double-click. I tried the jasco support site and there is no driver listed for this model.
Comment by vaska, posted on Nov 12, 2007
my GE 98763 wireless mouse is not working, where can i get a driver for it? Is it supported by Windows Vista?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Keyboards and Mice:
Top Keyboard and Mice Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Keyboard and Mice Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
