Question about Kicker 05C104 Car Subwoofer
Kicker cvr how to put the wire in place to get earth quake bass
  • Anonymous Mar 19, 2014
    Need wiring diagram
  • 752 Answers
What wire are you refering to?
Posted on Sep 22, 2007
SOURCE:
Can I wire a 2ohm Kicker CVR with a 4ohm Kicker CVR to a monoblock amp 1 channel
yes. google, impedance calculator and it will help you out on how to wire it
Apr 12, 2015 | Kicker Car Audio & Video
I have two kicker cvr dual voice coil 4 ohms to a
what about the remote power wire from the radio? 2 channel or four channel(amps)? are the speakers running parallel or in series? are you using a mono block? or an EQ?
Oct 13, 2014 | Car Audio & Video
I have a kicker sx650 powering two kicker cvr 102 at 2ohms but i havve no clue on where to set the settings at and i know this amp should make these subs pound. i need to know exactly what to put each...
How I tune:
turn amp all way down or disconnect rcas for now, turn up stereo to a song with some bass you listen to and crank it as loud as you would (not max about 3/4, use this to tune inside speakers (don't have bass maxed/distortion...)). Now dial in amp: turn up a bit probably to 1/4 or so then tune frequency I'd usually say around 100hz, then adjust gain again to where it sounds good...be easy on them for awhile to let them break in (don't blast them all day!). Usually bass boost is only 1 frequency with a curve (40hz or something)...so I try to not use it much....
Apr 25, 2014 | Kicker Car Audio & Video
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
I have 2 18" kicker
First you need the OHM rating of the subs. Most of the time its on the box or the magnet on the back of the subs (normaly 2ohm 4ohm or 8ohm) And that of the amp. Most amps are 4 ohm output if its a 2channel and 2ohm output if its a mono. You NEED to know these cuz wiring it wrong can blow channels in your amp or cause it to cut "in and out"
Jan 17, 2011 | Kicker Car Audio & Video
How to hook up two 10" kicker cvr for best sound
If they are single voice coil and are 4 ohm you can bridge your amp and run both speakers off of it so your amp sees a 2 ohm load....better bass that will hit harder....(series wiring) look it up on google....
Sep 25, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
What kind of amp
It depends on the box you are installing them in. If you're going for sealed box they you can put 600-800 watts on them as long as you're careful with the gains and bass boost off. In a ported enclosure I wouldn't put more than 600 rms on them and still be careful with the gains. set your filter on your amp to about 80 hertz and match it on your source unit.
May 31, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
How do i wire a kicker cvr if it has two reds and blacks
the sub is a dual voice coil, and depending on how you wire them, gives you different bass response as it drops the ohms in your amp. it can be wired for 2 ohms one way 4 ohms another way or 1 ohm depending on what ohm the coils are. to learn more about this got to rockford fosgate.com, click support, then click woofer wiring wizard, this will answer all your questions about dvc subs.
Feb 10, 2010 | Kicker CVR15-4 Car Subwoofer
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
2 12'' cvr kickers
ya u allreadyfound ound out the problem u have factory amps there u go after market
Feb 27, 2008 | Kicker CVR12 Car Subwoofer
Kicker 05C104 Car Subwoofer Logo
54 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
