Question about MSI 694T PRO (6309-470) Motherboard
Wiring hi i have just had to change my casing but forgot to make a note of where the wires from the casing goes to the motherboard,i know where there are meant to plug on but not sure how there go on the pins.the wires i am on about is the reset switch,power switch,led power and the h.d.d wire.if you could help it would be great.
    President:
  • 2,961 Answers
See the picture below:-
Posted on Sep 07, 2007
Ive taken apart a simpson delta 402 (0036A402P020) and forgot to take note of which side of the pump the black and white wires went to, I am wondering if anyone could tell me the correct placement for...
Hi just read your posting.The 2 wires you mentioned definitely came from the 2 terminals of the pump,Is that correct?Does your fan have a fan attached to it?Now if you have answered yes to both questions then the 2 wires can go to any of the terminals of the pump as it does not matter which way round they go.In other words the wires are interchangeable and it wont change the direction of the pump.Just to be sure, the black wire goes to one terminal and the white wire goes to the other terminal.Hope this helps and please reply to tell me how you got on or if you need further help.
Jun 20, 2010 | Washing Machines
Hotpoint Washing Machine Door Interlock (how to wire up)? I have removed the old door interlock and forgot to make a note of where the wires go, (wont make that mistake again) I have 3 wires White Brown...
The three wires you should have are
1-Brown-goes to L
2 Thin black to N
3 White to C..
Hotpoint never have incorporated a wiring diagram on any of their british made appliances, so previous comments made do not apply in this case.
Hope this helps.
Jan 03, 2010 | Washing Machines
I am about to switch out the motherboard for m5640 aspire 1
New motherboard will have a picture of the pin connections and where they connect on the motherboard. Just follow these connections, also the wires leading from the from the front of the case to the motherboard are labelled as to what they connect to. As a final note, the white wire on the connectors is usually always the ground wire, so look at the drawing carefully to see which side is the positive and make sure that the coloured wire goes to the positive side not the white.
AS ALWAYS INFORMATION IS FOR EDUCATIONAL PURPPOSES ONLY AND WHAT YOU DO WITH IT IS UP TO YOU.
Dec 18, 2009 | Acer Aspire m5640 PC Desktop
I.ve changed my motherboard and no longer have a 3 pin connection for the case fan on the motherboard. I know that + goes to yellow and - goes to black but where does the sensor wire go?
Hi:
An option for you is to just purchase a cheap adapter to plug your case fan into a unused power supply plug, such as one that plugs into a hard drive or optical drive.
Dec 11, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Wont start after disasemble and cleaning. just redlights and i think my wires are wrong cause i forgot how it goes.
Which wires do you mean? The wires for the reset and power buttons on the case? The pin arrangement is usually part of something called the front panel header, it's a series of pins for stuff like the power LED, HDD led, and speaker. The pin arrangement should be in your motherboard manual. If that's not what you're talking about please clarify. If you're in the Washington DC/Rockville MD area, please shoot me a line at Inovagent.
Nov 03, 2009 | Shuttle AN35N Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
On/off switch
Usually the power on button only has two wires. Then you have HDD led leads, reset leads, power led leads etc. These are all separate wires that fit onto separate pins in the Jpanel1 (front panel header).
Could be that the really old emachines grouped all these wires and made them into a plug to fit their own style motherboards.
If this is the case then that connector would not be on your newer motherboard, and it would have that Jpanel1 instead.
Hope this helps as I'm not very familiar with the old emachines.
Hank
Jul 08, 2009 | Intel Desktop Board D815EFV (BOXD815EFVLU)...
Dell motherboard
If you mean the front panel power switch the connectors are in most cases located in the bottom right corner as below:
Note that your wire setup can be difrent form the image.
If you need more assistance let me know, I'm here to help
Apr 13, 2008 | Computers & Internet
Open Questions:
See all MSI 694T PRO (6309-470) Motherboard Questions
MSI 694T PRO (6309-470) Motherboard Logo
98 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Prashant M
Prashant M
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
