LG WFT1071TP Top Load Washer
Problem for LG WFT1071TP Top Load Washer
Lg washing machine wft855a top loader
By shahani on Sep 07, 2007
washes but when it comes to rinse cycle it does not rinse or spin or drainn any water out
Same Problem
Sep 08, 2008
-   Hi, Please help..
My LG WTF-6517TC does not rinse and spin. The WASH function is working perfectly but when comes to RINSE, it is not draining any water out. So, I power off and choose the SPIN function, it is also not working and not draining water out. What should i do? Please help....-   Sayang2829
Dec 09, 2007
-   I'm having similar problem with a wf-t753a top loader. My problem is that it's not pumping enough water to fill the machine on the rinse cycle, so the wash and spin stages never finish. It is pumping just fine on the initial wash... Am just trying to work out how to pull it apart without breaking it!-   st3v3
Best Solution
posted on Dec 10, 2007
Helpful)
st3v3
Rank: Apprentice
Rating: 85%, 2 votes
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Comments:
Dec 10, 2007
- PS: The part number that I needed to replace is 5221EA2001D (aka 5221FA1921V) or A181. I found a non-genuine version for under $50 AUD on ebay. There is also a single valve version Part Number 5221FA1921W.
Was this helpful?
Yes
No
Popular Solutions for LG WFT1071TP Top Load Washer
Questions and Unsolved Problems for LG WFT1071TP Top Load Washer
Do you recommend LG WFT1071TP Top Load Washer?
Answer
Answer
my lg washing machine wf-s6607tc soon after start washing it stops then spin and drain lights comes.... (More)
Answer
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and... (More)
Answer
My fully automatic Fabricare LG machine just stops before the spinning process has to begin. We need... (More)
Answer
water accumulates inside drum and leakes out in my LG top loading machine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG WFT1071TP Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14851
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
