Question about Memorex MMP8565 MP3 Player
Memorex mmp8567 when i turn the mp3 player on it will give me an boot error shutting down message.
  • 2 more comments
  • jbizzlebear Nov 24, 2007
    it always says boot error shutting down how do i fix this?
  • rqlt423 Nov 28, 2007
    i got the mmp8567 in june 2007. i've always had problems with it freezing and occasionally shutting off, but now i can hardly ever get it to turn on and when i do it only stays on for 5 minutes (battery is fresh). i've called memorex and they told me to download firmware and format the player. neither of these things helped.
  • Anonymous Dec 19, 2007
    i turn it on and it say's boot error 1, shutting down;-1
  • AveMn May 07, 2008
    Same error, boot error shutting down. Previous attempts to update firm ware fail due to the player shuts down before pc can do anything, reset the item by means of battery removal fail.
    Item does not work as of now.
How do i format my player
Posted on Jul 06, 2009
MMP8567 Digital Audio Player with 2GB Flash Memory
I also had problems with the error message “boot error.” So I thought time to buy a new MP3 player, but first let me try and upgrade the firmware. At first it would not work, so I figure make sure I had the music I wanted on my pc and just format it. I formatted twice. Then I finally download the website from the URL below and tried to upgrade it.
Then I installed the software on the PC and it installed a program that tried to upgrade the firmware. At first it would not work, so I looked at the directions which told me that the mp3 player had to be in an upgrade mode or something? The first time it failed so I tried again. So it had me hold down the pause button disconnect USB wire from the PC and slip out the battery (mp3 player) quickly plug the USB wire back into the PC while holding down the pause button and the firm ware upgraded. So far so good and I put over 100 songs back on and it is working. Hope this helps
http://www.memorexelectronics.com/html/downloads.php
Posted on Aug 17, 2008
SOURCE:
When I turn my player on it says boot error, shutting down I have songs on it and have been using it for five months. This is a new problem. Memorex mmp8567
Memorex=3M. Like the video tapes, it's guaranteed for life. There's probably nothing you can do yourself if it uses MTP as opposed to UMS, otherwise you could just format it on your PC and start over.
Oct 30, 2009 | Memorex MMP8565 MP3 Player
Boot error
Problem Solved: My MMP8567 screen read ''boot error shutting down''.
Everytime I plugged it in to the computer the computer would find it but then it would disappear almost immediately.
I downloaded the Updater program from Memorex but it couldn't find the player.
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' 'Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
SOLUTION: I finally held down the LOCK/UNLOCK button and plugged in the usb cable. My computer found the player immediately and a software driver window popped up asking for a driver. I let windows search the internet and it found and installed the driver. The driver it was looking for was: ''player recover device class driver'' After windows confirmed it recognized my mp3 player I started up the Firmware update program and was able to update the player.
I tried to be clear and detailed. Good Luck ;-)
May 06, 2009 | Memorex MMP8567 MP3 Player
Device is detected, but I can't add music, because it undetects
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
Jan 31, 2009 | Memorex MMP8567 MP3 Player
I have a mmp8567 and it is giving me Boot Error Shutting down
Update the firmware. Download directly from Memorex site, Support section.
Jan 06, 2009 | Memorex MMP8567 MP3 Player
Memorex mmp8567 boot error shutting down
Nov 30, 2008 | Memorex MMP8567 MP3 Player
Boot error
Hello all:
I just resolved this same boot error problem with my Memorex MMP8567 mp3 player. After talking to technical support, they could not resolve it, so I decided to try it myself. Here is what I did step by step:
1. Downloaded and installed the firmware for the player from memorex web site.
2. In windows xp, click on Start>All Programs>Digital Audio Player>Memorex MMP8567 Firmware Download to start the firmware program.
3. Connect the USB cable for the player to the computer's USB port.
4. Remove battery from the mp3 player and connect it to USB cable. At the same time depress and hold BOTH the 'menu' button on the left of the player and the volume control button on the right of the player for a few seconds until you see "initializing" in your firmware software program. Then click on the "format" option within this same firmware program. (Note: this will erase all your files on the player, but will also get rid of whatever is causing the boot errors!)
5. When the firmware program is ready, click on start and wait until it is finished.
6. Your MMP8567 should now work just fine!
I hope this helps out someone. Good luck!!
Katai
Minnesota, USA
Sep 20, 2008 | Memorex MMP8567 MP3 Player
It says boot error shutting down and my pc won't recognise it
I have also had the same problem. Go to Google mail and type "MMP8567 boot error" in the search. You will get results where there is links to get the firmware. Especially, from FixYa. Down load the firmware and install it in your PC. Then it will format your player and install the new firmware. Your recorded songs will be lost.
Sep 06, 2008 | Memorex MMP8567 MP3 Player
Boot error/won't save files
does the website have a firmware update avb for this memerex.com ect
Jan 27, 2008 | Memorex MMP8567 MP3 Player
Have you updated with the latest firmware? It's posted on the Memorex site:
Jan 12, 2008 | Memorex MMP8567 MP3 Player
Memorex MMP8565 MP3 Player Logo
766 people viewed this question
Top Memorex Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Joe Negus
Joe Negus
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
