Question about iLO 3200 32 in. LCD Television
TV NOT TURNING ON
TV WILL NOT TURN ON, IT TURN OFF BY ITSELF WHEN WE WERE WATCHING IT, AND NOW IT DOESN'T TURN ON
    Scholar:
  • 133 Answers
Try another power outlet, if that fails, check the fuse. Having tried that to no avail, check up on your manufacturer's warranty - if it's in warranty get it returned for repair.
Posted on Sep 07, 2007
SOURCE:
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
My Toshiba rear projection TV -43hx71 is periodically turning itself off and on while we are watching a program. What could this be?
When tv shuts down for some reason, does it turn on again itself or you need to press power button to turn it On?
Let me know how old is this tv and any other related info that you think might be helpful to diagnose problem.
Thanks.
Oct 31, 2010 | Toshiba 43HX71 43" Rear Projection...
ILO TV turns off by itself.
Is your sleep timer activated? Check your menu settings. Or maybe some kid with a universal remote turning it off? Try covering the remote sensor with duct or electrical tape and see if the problem persists.
May 26, 2009 | iLO 3200 32 in. LCD Television
SVA TV will not turn on. The TV seems to be turning on then turning itself back off.
I've got old sva tv I was watching tv n went off then didnt com on any suggestions plz
Nov 23, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Tv turns on by itself
Hey Bubba,
If your TV is turning on by itself at about the same time each day you may have a timer activated, turn it it off, the TV's micro might need too be reset. To reset unplug your TV from the a/c outlet for at least 5 minutes.
Jun 05, 2008 | RCA P52926 52" Rear Projection Television
Wont turn on at all...
read info at ctechnicians.com email for questions
Dec 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
iLO 3200 32 in. LCD Television Logo
50 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
