I have HP Pavillion dv6345us with Slimtype DVD A DS8AZH ATA Device as DVD RW drive
from past few months I m facing a problem that DVD ROM is unable to read DVDs that i write with Nero or windows (or previously written data DVDs)
but DVD ROM can read any CDs and original DVDs
and also the data DVDs can still be made which are readable on other systems,
SO, there is nothing wrong with the drive as Original DVDs can be read easily.
I have googled a lot for the solution and tried every solution I found but condition is still the same.
Initially I did the registry solution given by microsoft and it was rectified but after few months I found the problem has again started occuring and this time I am unable to rectify it. (as registry is already changed)
I have tried unistalling the product like everyone says as a solution and restarted the system, the drivers got installed through windows but the problem still remains.
I am unable to find the driver for Slimtype DVD A DS8AZH ATA Device on the internet
I heard of Fixya a lot from my friends.
I hope I will get a solution here
Regards,
KL
Comments:
Apr 08, 2009
- hi..
drifterK
thanks for the reply...
mine HP Pavilion dv6345us is a laptop and the DVD ROMs are custom made for each laptop model by HP... so it will b hard to get a replacement
will installing xp resolve the problem???
Apr 08, 2009
- hi.. drifterK
thanks for replying :)
i will try installing XP ... :)
and let u knw if problem still persists
hey, do u knw where i can find Slimtype DVD A DS8AZH ATA Device driver
Apr 14, 2009
- hi...
i m bound these days so i cant install XP ..
so till den i will wait for some support from FIXYA.. :)
I found this problem to more users of this model ..the only thing I can advice you is to try to change with another comp model ....some have a lot of theories ..about it ...and long fixes..but It seems that the problems came with some vista updates ...so ..either get on xp sp3...cause its reliable ..or change it ..cause it will never work proper..
Comments:
Apr 08, 2009
- I looked for it today ..I will look for ..but I suspect that it is not present cause it is loading automatically on OS installation .. and yes ..I do believe that installing xp will fix it .....you can also try to reinstall nero with a secure and licensed one ..I don't believe that is anything wrong with the drive ...cause it still runs several type like original dvd .. http://answers.yahoo.com/question/index?qid=20070420210852AASl6B5 this is the address from where I decided that going back to xp will fix your problems... anyway ...first be sure you have all the drivers for the sound and lan conexion ...and image ...and then you may try ...I am still running xp sp3 ...and Im more than contempt ...I have no desire what so ever to use vista ...cause it seams that its full of issues related of drivers ..and updates that do not work ...and it consumes a lot of resurses ..bringing nothing that important ..but some graphics ...that arent that impressionat..:P Good luck ...and if you have any problems ..just post coments and I receive mails... I will look for the driver ..but you will not need it ...xp has the drivers for dvddrive build in . good night !
Toshiba A210 19T notebook.running xr home recently just started goes past post then starts to beep...
(More)
Toshiba A210 19T notebook.running xr home recently just started goes past post then starts to beep continually shows a black screen with the cursor.If I press escape windows boots as normal. Have also started to get a clicking noise when I open up a sub menu goes when it is closed. Any ideas on this thanks
I have a livebox B100 conected to my desktop (working fine). I have a wi-fi laptop which has worked...
(More)
I have a livebox B100 conected to my desktop (working fine). I have a wi-fi laptop which has worked fine for the last two months - picking up from livebox. Now it won't connect and neither will my ipod touch. Any ideas? I do have a nine year old who uses the laptop (but not the touch) so maybe he has deleted a setting?? I have tried re pairing them and have also contacted Orange - no help at all. I am NOT computer literate . Any help appreciated
i am having issues when i try to view a video movies/songs n links even from you tube it keeps on...
(More)
i am having issues when i try to view a video movies/songs n links even from you tube it keeps on pausing the video even thou i have full service. its a emachine laptop E627
