Question about AcerScan 620U Flatbed Scanner
Set Parameters Failed
I used my Acer scanner for years on my old computer with no problem. I installed it on my newer (rebuilt) computer. It all looks different now. I don't know if my son had it working through a different program (like Photoshop) or what. The thing is, that not long ago I successfully scanned a picture. I swear that in the startup menu, it had a mirascan scanner choice, which I don't have now. I realized that the installation disc that I have is disc 1. I can't find a second disc- my son may have taken it out of state- but whatever I did- maybe found the missing information online, including driver updates, I have lost this when I uninstalled and reinstalled while trying to solve this issue of not being able to scan successfully. The startup menu shows mirascan V 3.20, with choices of mirascan help and uninstall. I don't have the choice to go to mirascan scanner. It has 'copier'. In this, I seem to get everything ready to scan, but when I press the 'scan preview image' an error comes up saying 'set parameters failed'. I searched the entire help menu and it does not address this problem. I don't know what the message means- there seems to be no way to either set parameters or to remove them. Can you please tell me what I need to do? Thanks a bunch- Patti Rizzo
  • 1 more comment
  • momatomic Sep 07, 2007
    I forgot to mention in my above post that my scanner is an Acerscan 620U Prisa USB- Patti
  • momatomic Sep 10, 2007
    My computer is a Compaq with Windows XP home Edition It has an Athlon processor? 650+ MB of ram- i hope this helps, and by the way thanks for your help- sorry I forgot to rate it
    I don't know if this has anything to do with it, but when I uninstalled and reinstalled the scanner it gave a message that the uninstall was incomplete. When I would try to open scanner it says a dll file is not found-
    One says ImgProc.dll The specified module not found. The driver cannot be opened. I know this must be something simple- but so is my knowledge. I mean I had it working once, but i don't know what happened.
  • momatomic Dec 13, 2007
    I just wanted to comment further that with both of us- the scanner worked for awhile with our newer systems- mine being XP home edition.
    Why would it lose compatibility when it had it once?
    I am going to redo the suggested compatibility test, as I have already updated drivers,etc. Could an updated driver cause the loss of compatibility?
    I will work on this until i get a solution, which I will happily share! Good luck to those of you who have the same problem-Patti
I have the same problem with my Acerscan 620U flatbed scanner which I have used for years, even with XP home SP2 & 3, after I reloaded the Operating system on the same machine, (after a crash) It would not work properly, so I searched for new drivers and softwareafter not finding anything useful here, I went to and found 2 files for the 620U. A zipped file containing the original (Win 95-98) install disks - 2Megs, (pasted from Driverguide);
Model Acerscan 620U Manufacturer Acer Set Parameters Failed - info_icon.gif Operating Systems Win95, Win98 Device Type Scanner File Name
Uploader Notes This is the install softwarefor the AcerScan 620U, which is the USB model. I wasn't able to find itanywhere on and when I tried to download the latestversion off of the Acer website it didn't work, crashed my graphicsprograms. This one worked perfect.How it works
This will give you and
Unzip to a folder called disk1.
Unzip to a folder called disk2.
Runthe 'Setup.exe' file in the 'disk1' folder - halfway through it'll askyou where 'disk2' is. browse to wherever you've unzipped disk2 andthat's it!
I also downloaded a 14 meg file "mirascanv403u10.exe" (<a rel='nofollow' href="">Acer AcerScan 620U Driver</a>) which is supposed to work with W95-98, ME, W2000, XP (with mixed reviews)and Mac-OSX, I haven't tried either of these yet although I will try the Mirascan file first. For many users the difference may be that when setting up an XP machine you have the option to use a FAT32 file system or an NTFS partition, it may be that the software doesn't work with the NTFS partition/filesystem.
If you send me a request to I will send you either or both of the files as an attachment until Jan 10 2009 then I delete them, (or you can get them from Driverguide) I'll also let you know what worked for me.
Posted on Dec 27, 2008
I'm having the same problem with my scanner Primascan Colorado 2400. Looking for a solution I landed on this page.
Website of scanner:
Answers there: nihil.
I bought this scanner some years ago. Worked very well with WindowsME, and until yesterday as well with WindowsXP-SP2 on my overall usually very compliant and compatible modern computersystem.
I used to scan from IrfanView. It always called the scanmanagerprogram very satisfyingly.
But as of yesterday following error-message:
(translated from Dutch) "Can't find entrypoint of procedure _P_ImageDownSample@24 in DLL-file ImgProc.dll."
I've noticed that WindowsXP has two ImgProc.dll's in \system32.
One from the scanner-installation and one probably installed with WindowsXP.
I've installed and reinstalled this very decent scanner several times. And it gets wel detected, without hardware-conflicts.
But, as it worked perfectly before on this same system, it suddenly doesn't anymore.
A pitty.
Maybe I will come back here when I've found the solution if noone else has by that time.
Posted on Dec 02, 2007
  • 2,985 Answers
What computer system is it used with?
Posted on Sep 07, 2007
  • john ash
    john ash Sep 10, 2007
    This scanner was produced and used in the Windows 95/8/ME era which were DOS based systems.
    You have moved to XP which is a NTFS system - completely incompatible with DOS based scanners.
    A scanner[and in this case its SCSCI card] has processor firmware which responds to DOS commands.
    The computer is sending NTFS commands -they no talky to each other.
    Two thing to try - Acer to see if a XP type software was produced for this model[probably not]
    Check out the compatibility of the program/software.
    Right click on program icon and click on properties/then compatibility/ then 'Run as for Win 98.
    Come back to tell me what happens
  • john ash
    john ash Dec 13, 2007
    Patti - it is likely- though I am not certain- the 'updated' drivers are no longer DOS compatible,
    The only course of action is with ACER direct to see what they can suggest.
    It is possible the old drivers and DLL's exist somewhere in a file for legacy equipment
Acer extensa 5420 with bad motherboard. I want to buy newer Acer and put hard drive in so can use old data. Which computers will old hard drive work in?
Try to stay close to the same year of production. Depending how old it is, typically you can just install the hd in another Acer and off you go.
Oct 04, 2013 | Computers & Internet
I am thinking of buying a used Hansol 550 - three years old. Do they deteriorate with age ? Do all the old models have speakers fitted ?
3 years old will more likely to need new set of caps, not all monitors come with built-in speakers. See failed monitors due to bad caps:
I would not buy a 3 years old 15", save the money for newer and bigger monitor.
Feb 10, 2010 | Hansol H550 15" LCD Monitor
I installed my vupoint scanner software (FS-C1-VP), but when i plug in the USB, it says that the hardware is not found and the USB root hub is not found. i have it on an old dell computer (circ 2001) with...
i went to a newer computer (my wife's Dell, which is only 2 years old), downloaded the software and hooked it up and it's fine. must have been because my older computer that i tried it on had problems with its USB connections
Aug 26, 2009 | Office Equipment & Supplies
Scanner problem
if you are using XP the the microsoft scanner may already be activated. look for the icon in the my computer window
if not
install the lexmark driver package or software from scratch removing the old one first....get a newer version from their site...
vuepro32 is a fast and great program for scanning...
try it after the re-install i fixed and scanned over 40000 images with it all good
good luck
May 18, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
The application failed to initialize properly
I have the same model and problem if installing from original CD on Windows XP (the driver is old and not for XP). The new XP driver will work.
Mar 25, 2009 | Genius ColorPage Vivid Pro Flatbed Scanner
Acer 5520 restore failed 0xa000000e
I got it to work by deleting all the partitions on my drive (I first loaded xp, loaded system commander 9, and used that to delete all the partitions.)
Then while booting from the recovery cd, holding down alt-f10, the recovery dialog said it was partitioning the drive. (I didn't see this before, even if I partitioned the drive like it came from the factory.)
Then the rest of the recovery worked.
Feb 11, 2009 | Acer Aspire 5520-5908 Notebook
I lost my softare driver for acer flatbed 640BU scanner
first decide on which particular operating system you want to use use the scanner. Then try to install tyhe drivers. If on both check for the architecture as well 32 bit or 64 bit. Initially uninstall alln the entries for the scanner from add and remove programs or delete all the entries using microsoft cleanup utility tool. Then try installing the drivers it should work.
Jan 24, 2009 | AcerScan 640BU Flatbed Scanner
Acer (BenQ) 620 scanner cannot scan transparency
Can you put some backing on the transparency and scan it like a regular item?
May 05, 2017 | AcerScan 620PT Flatbed Scanner
Symbol Spark LS 1004 Problem
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
If you don't know ask me. we don't want to lose al the settings.
good luck
Nov 29, 2007 | Symbol Spark LS 1004
Acer Scanner 310P Drivers for Windows Vista
I have a Acer scanner with mirascan 3.40 it does not work in winxp. can u help me to solove this problem. My Email Id
Apr 26, 2007 | AcerScan 310P Flatbed Scanner
AcerScan 620U Flatbed Scanner Logo
525 people viewed this question
Top Acer Office Equipment & Supplies Experts
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
