Question about Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television
Ws-48313 no power
Will not turn on. Solid green led when plugged in otherwise no power. DM board repair not applicable, no DM board in this model. No capacitors look bad visually but have not had chance to check with cap checker. Does have 5 volt standby and the 10 volt standby line shows as 20 volts. I do have the schematic but thought somebody here might have a quick solution. Thanks
  • 8 more comments
  • Jeff Gordanier Sep 07, 2007
    I didn't have any voltage on pin 3 so I replaced the part. Didn't fix. Pin 1 has 20.7v, pin2 has 19.8v, pin 3 .9v, and pin 4 has 5v.
    I traced back from pin 2 of pc9a21 and found q9a55 and d9a28 shorted. Replaced both and checked d9a29 zenier diode but did not replace.
    4.7 volts restored to pin 3 of pc9a21.
    Now power supply starts up and then shuts down after about 2 seconds. Error code flashes 22 for short circuit. What should I look for now.
    Also wanted to say how much I appreciate your help.
  • Jeff Gordanier Sep 08, 2007
    I checked both fuses and f9a05 5amp is open.
    Looking at the schematics the -24v line goes to the STK394-250 chips. Are those the convergence chips?
    How can I tell which amp to replace? Or should I just replace both.
  • Jeff Gordanier Sep 09, 2007
    I checked all the resistors and none look smoked and using my meter they all check ok. Should I go ahead and replace them anyway? Thats a ton of 2 and 3 watt resistors.
    Also should I replace D9A61 and C9A74? They set in parallel behind the fuse that blew. I was thinking that although they test ok they might have been stressed by the current before the fuse blew. Does the convergence amps going out ever take the two coils out that feed the -24v.
    Thanks
  • Jeff Gordanier Sep 11, 2007
    I had another question. When I shine a flashlight down into the picture tubes I notice that there appears to be debris laying on the bottom of the lens. Should there be anything floating inside the coolant liquid. Can the liquid be easily replaced? If it can will the seal have to be replaced or reused? I can order the fluid from mcm electronics. If I can do this how much realignment to the tubes will be required.
    Thanks
  • Jeff Gordanier Sep 15, 2007
    Hey troylove11,
    I accidentally hit accept button on this page but tv is still broken. So I have to try and get in touch with you this way.
    I replaced the convergence chips and the resistors and then found a bad cap in the -27v line right behind the rectifier diode. Replaced diode and now -27v back but it now shuts down with a 21 error. I know this is an x-ray error but what are your thoughts on what to look at next.
    Thanks
  • Jeff Gordanier Sep 25, 2007
    I replaced the regulator and that didn't fix it. I also basically replaced all the caps in the power supply. Except the big filter caps.
    What should I look at next?
    I now get an xray protection error. I replaced all the power supply caps just in case and I replaced the voltage regulator. Still the xray error. Any thoughts on what to look for next.
  • Jeff Gordanier Sep 28, 2007
    If the HV doesn't come up will that give a false xray protection error?
    I was trying to figure out why the HV regulator ic (mspad401) was not putting any voltage to the HOT. I traced back from pin 3(HD IN) and found that pulses were indeed coming from the deflection circuit. But they were stopping before a resistor tied to the collector side of a transistor that acts like a switch when the tv is first turned on. I checked the voltages around this transistor and checked the transistor and found no problems. I then removed the mspad401 ic and re-checked voltages and signal and the pulses have returned. So does this mean the hv driver ic is bad? Or have I missed something.
    President:
  • 3,130 Answers
Look for swollen capacitors in the sweep power supply as well as in the main power supply. Make sure the main regulator is regulating at the proper voltage. A lot of times in these TV sets, the slight over voltage can cause the set to go into an x-ray protect mode, therefore confusing the real problem. Capacitors are very very common in the set to go bad. Good Luck
Posted on Sep 19, 2007
  • Larry  Dillon
    Larry Dillon Sep 28, 2007
    Did you get the service manual for this TV set yet? If you did, send me a copy please to techman32k@yahoo.com
    Genius:
  • 1,153 Answers
This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. Hope this helps if not let me know and I will go further
Posted on Sep 07, 2007
  • 1 more comment
  • Lashawn Robinson Sep 07, 2007
    Sounds like you are on your way to fixing this set! Ok now you can check:Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB.
  • Lashawn Robinson Sep 08, 2007
    You are correct! part # 283P144080 Yes and the convergence amps are probably the culprits. Remember also resistors in same area(replace)
    Replace both to be safe, make sure you get good parts also I would go back with same maker. Also remember return resistors also in same area.
Blinking green led light after power outage will not reset set is approx. 6 years old model mitsubishi w55511
had same problem with my tv.Technician told me to remoe front cover and unplug the 2 plugins going to the buttons then try the mistubishi remote to turn tv on.Did this and worked fine with remote.
Apr 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi 65" model # ws-65511
The steady green blinking led is due to the DM not completeing the boot Cycle. You can get the repair kit at the following link which contains the replacement Capacitors and step by step detailed instructions so you can do the repair yourself. Very inexspensive Kit
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Mar 02, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Green light flikering
Replace all 7 capacitors in the DM Module on the DM Power Supply Board. If it is similar to the WS-65869 and WS-65513 it will have a metal enclosed DM Module at far left of chassis, looking from rear. About 4 or 5 connectors, screws, and Module slides out. Take top shield off. Take good notes or use digital camera or video recorder to make re-assembly easy. These capacitors are 1000uf@16 volts. They always check good, just replace them! After re-assembly plug AC in and wait 90 seconds or more (green Timer LED will stop blinking), then press Power button. If Timer LED doesn't stop, look for small pinhole (System Reset) and press switch with pen or small screwdriver, then wait for green LED to stop blinking. Then Power On TV.
Feb 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Need a repair solution e-mailed
Good Day, jnjetsn;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
Good Day, nixonam;
Mitsubishi ws-55513 blinking power light
The infamous flashing green LED problem is usually due to a failing or faulty DM board. I purchased the PDF manual online and was able to locate and remove the components as necessary.
If you can solder, and are semi-proficient with electronics it is 4 bad capacitors on the DM board...
Otherwise there are facilities that can repair your failed board for about 275.00 or replacement of the board is between 350.00 and 500.00 buck USD.
Good Luck with your repairs....
-Richard (MetalDad)
email: PentiumDreams@aol.com
May 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Green power on light flickers
You may need to repair the DM board, do you have any solid state repair experience? Check this out, it is already posted here! http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good Luck to you!
Jul 30, 2007 | Mitsubishi WS-48313 48" Rear Projection...
Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
