Question about Fans
Hunter Ceiling Fan Problem
Model 20756-300 S/N: 0335286 Type 2 Using pull chain, from Off: One pull (high speed)- nothing happens Second pull (mid speed) - motor hums, rotor barely turns. Third pull (low speed) - same condition as second pull Light works properly. Thanks! JT
SOURCE: we have a hunter type 2 ceiling fan installed on a bedroom ceilin
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Posted on May 12, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Posted on Aug 20, 2009
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
  • 4 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
It's a 3-speed ceiling fan that's for sure. I think the same a fixer1950 already said...
This page about <a href=>hunter ceiling fans</a> might be interesting...
Posted on Oct 09, 2009
  • 57 Answers
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Posted on May 16, 2010
SOURCE: need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Posted on Oct 10, 2010
0 characters
1 Points
My hunter ceiling fan turns very slow
Check your capacitor. If this is an add on remote, set the fan on high with the remote then pull the chain on the fan until you get high speed.
Sep 17, 2014 | Hunter 52" Ceiling Fan With Light And...
High and Medium don't work, only low
Check your capacitors to see if they're bad. That's the black box near the pull chain switch with wires going to the switch. If bad call 1-888-830-1326 Hunter parts.
2 wire part # 74132-01-000 ( probably not this one)
Other capacitor part # 74133-05-000 (probably this one)
Jun 02, 2013 | Hunter Fans
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
Ceiling fan with broken chain on fan speed
Need to order new pull chain at 1-888-830-1326. Have model # available. 5 digit # starting with a 2.Also you want to write down what color wire goes into which slot.
Dec 21, 2012 | Hunter 52" Ceiling Fan With Light
Can a hunter ceiling wire to run on med all the time using a wallto cut the power
Yes you could set it up like that . if there is a wall switch .. and if there is a pull chain then it is easy to do this, use the pull chain and then select the desired speed and use the wall switch for on and off. IF there is no pull chain and there is a remote .. do the same with the remote. If none of that can happen then we need to go internal and find a combination of wires that will give you the medium speed .
Jun 11, 2010 | Hunter (25417) Ceiling Fan
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Wire diagram for pull chain on ceiling fan hunter original
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hunter ceiling speed.
A fan that old has a muilti speed capacitor. It could be that or the swicth. First thing to do is test the swicth with a voltage tester to see if power is switched to different posts if it does switch it is prob. the cap. Good luck trying to find one.
Apr 06, 2008 | Hunter Low Profile III 20807 Ceiling Fan
Fans Logo
161 people viewed this question
Top Fans Experts
Barrett Palumbo
Barrett Palumbo
Are you a Fan Expert? Answer questions, earn points and help others
