Question about Olympus Camedia C-3020 Zoom Digital Camera
Screen shows full memory card
Following a download of the card, it was reloaded, and took two pictures and commenced to show that the card was full again. repeated attempts to reset from the menu or to delete individually, only resulted in the deletion of the two pictures mentioned and the screen showing screen showing the card to be full.
  • Carol Chihara
    Carol Chihara Mar 17, 2008
    I have exactly the same problem.  on my Lumix DMC-FZ5. Only two pictures, then card full. Another card, same company, same size (128MB) is working fine. Hence must be a problem with the card.  Any way to get it back?
    Thanks,
    Scholar:
  • 133 Answers
It's quite possible that it's actually taking photos and storing them to the camera's onboard memory and not the memory card, explaining why it gets full so quickly with two pictures and why you can only delete two pictures. Look for a setting to change the storage to the memory card.
Posted on Sep 07, 2007
6ya staff
SOURCE:
MEMORY CARD SHOWING FULL BUT WHEN CAMERA CONNECTED TO DOWNLOAD TO LAPTOP OR DESKTOP ITS SHOWING FREE SPACE AND USED SPACE BUT NOT SHOWING ANY PICTURES AND VIDEOS,
Save the pictures and videos on the card. Try reformatting the card in the computer, and then again using the camera. The first reformat will ensure the card is empty, and then the camera reformat will ensure that it is recognized by the camera. If the camera reformat will not work, try a new card.
Apr 09, 2015 | Samsung ES30 Digital Camera
I have a no connection message on my camera. its been in the water once but worked after we got out the pool. then it was turned on again and the message came up. i plugged it in my mac and the pictures...
If your camera was submerged, it's likely that corrosion has commenced within the camera. I'm sorry to say that nearly all cameras that have suffered water damage are unrepairable as corrosion strikes at many points within the camera. However the memory card is much more durable. Remove it from the camera. Consider purchasing an inexpensive card reader to use with your computer to download your photos from it.
Dec 30, 2010 | Cameras
My Fujifilm s5000 camera turns on but when I go to take a picture it turns off. I can view my pictures but can't take any.
Your memory card or internal memory may be full. I've run into situations where the card full doesn't flash on the monitor or LCD screen because there is lets say 3 gigs of memory left but the picture you are taking is 3.5gig's it won't take the picture because there isn't enough memory to put the image anywhere. Download your pictures to your computer, format your memory card and all should be good again. If you are using the internal memory you will need to obtain (buy) a memory card for your camera and download from the internal memory each picture from the memory card one by one until all the internal pictures are on the removable memory card then download these to the computer. After you have them on the computer go back into the internal memory and delete each of thse pictures and you are ready to start taking pictures once again. it took me longer to type this then the process will take to do.
Dec 24, 2010 | Fuji FinePix S5000 Digital Camera
I have PrintMaster Platinum 12 that has been corrupted. I have repeatedly attempted to delete it so that I may reload from disc. Control panel does not permit me to delete it. Help please.
HAVE YOU REINSERTED DISC TO COMMENCE A SETUP?
A LOT OF PROGS USUALLY WHEN CHECKING SYS, ASK DO YOU WISH TOO REMOVE ASK DO U WISH TO REMOVE OLD PROG.
IF NOT, YOU WILL HAVE TO ACCESS PROGRAMS, FIND THE FILE/RIGHTY CLICK/REMOVE/IF FAILS/OPEN FILE/REMOVE WHAT DATA YOU CAN/RESTART/TRY SETUP?
Nov 15, 2009 | Broderbund PrintMaster Platinum Version 18
My computer has stopped downloading photos from my Finepix S8100fd. Have tried reloading the software that came with the camera. The reloading of the software seems to go perfectly but I still cannot...
I assume you're following the instructions in the manual.  If so, search your computer for connected drives - in Windows, just (double) click on 'My Computer'.  If the camera is connected, it will show up as if it's just another drive.
Open it - double click on it - then each folder in turn until a bunch of picture files show up.  Copy and paste that last folder to your hard disk and open the files in the usual way, with your ordinary picture viewer, not the Fuji software.
If the camera doesn't show up, remove the memory card and use a USB card reader - preferably borrowed - just as if it's the camera, as described above.
If that doesn't get your pictures onto the computer, you have either a camera or USB problem and it's time to get professional help.
If you are able to get your pics. downloaded, rename the copied folder on your hard drive, select all the files on the camera/card - NOT the folders - and delete them.  You now have a useable, empty memory card and all your pics in a meaningfully-named folder on your computer, and you're back in business.
For my money, the Finepix software is rubbish, anyway - and a card reader is usually quicker to download and doesn't use up your batteries!  Fuji's support site should be able to help you get back in business when you have time to research/e-mail them, though.
Sep 08, 2009 | Fuji FinePix S8100fd Digital Camera
D70s image file does not exist, HELP
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Oct 06, 2008 | Nikon D70s Digital Camera
Using Internal Memory...now says memory full, no image!
I own the same camera, Not sure about no pictures showing in the memory but you can get a 2 gig memory card for around $20 in stores or around $15 or $16 on ebay, holds over 700 pictures at the highest resolution. Also try to download your pictures to your computer if you haven't already. Hope this helps.
Sep 28, 2008 | Samsung Digimax A503 Digital Camera
DOWNLOAD PICS AGAIN
You say again, so have you reinstalled the twain drivers? And, do you have full administrator rights. When you right click on a picture to drag it to your destination folder try the user Administrator Rights.
Regards,
Worldvet
May 28, 2008 | Samsung Digimax S630 Digital Camera
Pc won't read new images off camera
Have you checked to see if you are recording to a separate file?
Mar 12, 2008 | Olympus Stylus 710 Digital Camera
Olympus Camedia C-3020 Zoom Digital Camera Logo
182 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
