Canon imageRUNNER 2020 All-In-One Laser Printer Logo
Posted on Apr 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ImageRunner 2020 paper tray open warning - cannot fix
We keep getting an error message that tray 2 needs paper. Have carefully reloaded and closed tray, interchanged tray 1 and 2, no help. The sensor must be bad or ??  Anyone had this problem?
Anonymous
Level 3:
  • Master 1,219 Answers
  • Posted on Mar 02, 2010
Anonymous
Master
Level 3:
Answers
1219
Questions
Helped
673767
Points
2880
Are you check the sensor flaper for paper presence?
It is located above paper in pick up assy.Whe you remove the drawer you should be able to see the black flaper hanging from above.
Error 000a0b no paper jam but they sense paper jam
With commercial machine like the ImageRunner, it is often staff roughly removing the jammed paper and leaving a tiny piece of torn paper over one of the sensors.
Remove the wall mains plug. Remove all the paper trays. remove the toner cartridge, open all the side doors and look carefully with a flashlight for a small piece of paper.
List of Error Messages - imageRUNNER ADVANCE 400iF 500iF
https://oip.manual.canon > ... > Problem Solving
Error messages are categorized by function. Select the function that corresponds to the displayed error message, and see the possible causes and remedies.
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
I have a canon imagerunner 2020I copier with a
this message is 90% from the second tray.try to close the small door of the 2nd cassette forcefully.if it does not work u can disconnect the second tray by unplugging the wire from the engine board on the back side of the machine by removing the back cover.it will be a yellow p/j in the middle of the board.u can easily trace it as it goes down to the 2nd tray.
2answers
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
1helpful
2answers
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
1helpful
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
4answers
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
old marine
old marine
ZJ Limited
ZJ Limited
