Question about Technics SL-1200M3D Turntable
Technic SL1200 M3D
Two Issues: 1) The firsdt turntable produces no sound from left channel, I've checked all connections and switch needles around and it must be the table. Is this my tonearm going out? 2) On the other table the tone arm pulls down and right. It has never done this before. Any help would be greatly appreciated Cheers, Loops
  • Anonymous Feb 23, 2008
    I am intermittantly losing audio out of the right channel only. the sound from the right channel comes and goes by gently tapping the top of the tone arm pivot point.
  • dustcart May 01, 2009
    im getting no audio sound out of the right channel of my technics 1210 . i assume the right hand phono cable is faulty. the left channel is fine. how can i fix this myself ? i was wanting to replace all phono cables on both decks and put 1/4 inch gold plated jack connectors on them instead of phono connectors. can i do this myself / is it relatively easy ?
    matt / plymouth / uk .
    Sergeant:
  • 432 Answers
Personally it\'s kind of funny that the peoples whicht say that you can\'t do it yourself are often peoples which make money by upgrading, fixing 1200\'s. While moest oem\'s comes with some movement and like i allways say: having the right tools, which are more expensive then the arm i have to say and it\'s easy. The mechanism is used in 10.000\'s products.. a pin and a bearing. Only using the right amount of torque and every idiot can do it.But most peoples just don\'t read how a turntable works, and two guys on youtube make a lot of video\'s , just turn the turntable upsidedown , with the townarm on a pillow-->idiot and then he makes some movies how to ground it and take apart the tone-arm and pivot and if you do it that way, your tone-arm is lost. It\'s funny to see how he does even the tonearm with a 2 dollar, all in one thing and at a moment he screws the vertical tone-arm screw tight and then just a bit less tight, while the technics bearings ain\'t high quality bearings, so in fact is that tone-arm quite dead. My opinion: when you buy a second one , buy the tonearm for 90 dollars, buy a piece of deskadel tonearm wire from 60 cm, use two cinch ouputs at the bottonplate and rewire from sme-connector to rca-output(normal brand 40 dollars/2) and offcourse put the high adjustment etc in new oil/grease . Then you don\'t need to screw at the ballbearingsites, just remove the sme-adapter and pull the new cable through( pain ).
Resolder the shitty standard wire and offcourse remove the pcb which connect the tone-armwire , to the rca-cable coming out of your gear and throw it away. Be gentje when soldering, first rub it up a bit with fine sandpaper, take shrinkplastic over every lead, a small piece and solder it fast and good. If your too slow, the plastic melts. That whily a put a cartdrigde in in, so the connectors have more space, but don\'t overheat. And you alleays can buy a new sme mount incl again the technics cables for 16 dollars.
But watch the youtube video\'s, only THINK
Posted on Jul 22, 2014
  • 515 Answers
1) This turntable either has bad RCA cables or a faulty tonearm - in either case, none are easy fixes. FYI, If you use Ortofon Concorde series, they are notorious for causing faulty connections with your tonearm, and eventually deteriorate your tonearm over time. So you might want to think about changing them if you get a new tonearm put on. If you use the Technics headshell, you are fine. 2) This turntable definitely needs to have the tonearm replaced. Once the arm comes loose from it's bearings, it's next to impossible to get it back to factory specs, and you will have skipping issues. Both will require professional servicing. Check out www.1200s.com if your in the NYC area.
Posted on Sep 23, 2007
  • richard vreede
    richard vreede Jun 04, 2014
    since the tone arm is a easy replacement and not expensive, a new 1200mk2 cost me 60euro, while the 1210 costs 50 euro more....just for the color.
  • richard vreede
    But using a right expensive torque 'screwdriver', makes it easy to just remove the arm and assemble it again.
Four wires coming from needle to cable, two are shield and two are left and right channels. Which color goes where
Actually it's not to hard to connect them. All you need is a stereo record where you know a sound of something is on the right or left channels. I use to have a Goodies LP where a one of them would say "bounce to the left" and the other said "bounce to the right" these coming on the respective channels.
To set it up just stick the red (right) on one of the cartridge pins and white - left on the opposite side - not underneath it. Then connect the other two to the pins below them. Play your test record. And if the sound which is supposed to be on the right channel come on the left - swap the two red and white wires around.
If the sound sounds (tinny spaced) out then swap the same side wires around.
So if you have say Red Green, Make it Green Red. If it is tinny only on one channel, don't switch the other channel around.
For example the right is tinny - do the above - but leave the other White Blue.
By the way some cartridges do have L and R marked on them and + and - for the channel types. " -" being for the green or blue wires.
Feb 08, 2014 | JVC Audio Players & Recorders
Left channel not producing any sound, right side works perfectly
Disconnect the wires to the cartridge. With the amp on. Touch each wire (one at a time) with your finger. Two of the wires should buzz (1 left, 1 right) if the left doesn't buzz either the connections are faulty or the pre-amp in your amp is.
If you get a buzz on the left, replace the cartridge.
Oct 16, 2013 | Technics SL-1210M5G Turntable
One channel on my sl1200 mk 2 has very minimal sound out put. I have to turn my balance selector on my reciever almost full right to balance the volume. Any insight to this problem is...
As a test, switch the right and left RCA cables from the turntable to the amp. If the problem reverses, the issue is in the turntable or with the cables. If it stays the same, its a problem with the amp.
Nov 16, 2010 | Technics SL-1200MK2 Turntable
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Apr 18, 2010 | Technics SL-1200 Turntable
Only one channel plays.
If you disconect the wires to the cartridge and with deck plugged in to the amp and switched on, you can touch the ends of the wires with your finger. Though there are four wires, only two should produce a buzz, one in the left, one in the right speakers. If you get a buzz in each channel, the rest of the unit is working fine and you have a faulty cartridge or a poor connection to it. If one channel remains dead, then you have a problem in the wires to your amp or an internal fault inside the deck. If internal I suggest you remove the bottom of the turntable and have a look around.
Mar 19, 2010 | Audio Players & Recorders
Buzzing from one Technics MK5 1200
More than likely your RCA's need to be replaced. There is no need to open it up, as the ground wire rarely every comes loose. It's held down by a screw & soldered to the circuit board. Unless you pulled on the ground wire.
There are only 3 issues which can cause this:
1) Technics Tonearm - Check the 4 prongs inside the tonearm. Make sure they are all clean (shiny gold), and all protruding the same distance. There are springs behind these prongs, and often times they do come loose over time or overtightening.
2) Technics RCA Cables - This is more than likely the culprit.
3) Cartridge/Headshell - swap out with your good unit. If it works, then your good. Just replace cartridge
With the exception of #3, the other 2 will require assistance from a qualified service technician, otherwise you could cause more damage to your turntables.
- OPTiC
Master Tech, 1200s.com
Technics Parts : Technics Repairs
Jun 16, 2009 | Technics SL-1210MK5 Turntable
1 X 1200Mk2deck higher volume / causing spkr not to work..
Problem If you swapped the two TT's would the problem stay with the connection on your mixer? At least then you/we would know wherein lies the problem. I'm betting thge low volume is because you have the phono jacked into a line level input like AUX instead of PHONO.
Typically, what you're describing is a phone source plugged into a NON-phono connection. (Tinny, low volume - classic lack of a phono preamplifier with RIAA equaliztion). A standard old-school tuntable requires a phono preamp that is labeled "PHONO". Nothing else will give it the boost and freq response correction LP's and phono cartridges produce.
Your problem #2 alludes to a channel problem with a turntable running through your mixer. This isn't rocket science. Swapping the two turntable channels around would probably change the apparent failing channel, right? Yes - Problem out at the turntable. No - problem in the mixer. You've already hinted at the source by monkeying with the tonearm wiring. You're on the right track. The tiny multi-colored wires in the cartridge shell are very thin and delicate. Their brass fittings sometimes oxidize and reseating them as you have done usually gives some relief. Kinks in the wires could cause your intermittent symptom. At the RCA end of the tonearm cables, make sure they're seated on with a twist to wipe off oxide.
Problem #3. Is it just bothering you or is there a functional problem, too?
Apr 21, 2009 | Technics SL-1210 Turntable
Harmon Kardon and Infinity Modulus
I got the answer for No-1.
The balance was turned on the Right Channel. That is why Left Channel was not working during the Channel test.
For Channel test the Balance should be in the middle so that both Right and Left Would be heard.
I am working on my Subwoofer Isuue.
I opened the Back Panel and Yet I could ot figure out any issues.
I will open the front panel and see if any connection is loose.
Dec 29, 2008 | Televison & Video
No Sound out of Left side
is it possible to swap the left and right wires on the needle cartridge? does the sound change sides? if yes bad cartridge if you still only get sound from right side try changing around the rca phono plugs
Jan 04, 2008 | Technics SL-BD22 Turntable
Technics SL-1200M3D Turntable Logo
472 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
