Question about Kenmore 94812 Top Load Stacked Washer / Dryer
Drum will not fill completely with water
The only way to fill is to hold the water level lever manually to large load
  • 240 Answers
Sounds like you have a water level switch going bad behind the console. Unplug machine, remove console and look behind the dash. You will see a switch that should have a small hose running to it. Gently remove the wires and hose and remove the switch. Be sure that if you replace it yourself, that the hose doesnt become disconnected from the outer basket, and be sure it is rehooked to the switch. Jim
Posted on Sep 07, 2007
SOURCE:
When i load my washer drum in washer will not agitate or spin off tract.
if noisy like plane taking off bearings gone check play on drum by pushing drum back and forth look for large gap between drum and door seal and listen for scratching noise when turning also some machines wont spin if the load is uneven
Dec 12, 2014 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
I put a fairly large load in washer. As the washing started I needed to add an item. I was surprised that the machine had very little water in it. Is there a way to add more water. Also when soaking I had...
The Series 10 and 11 machines have three level fill points the Series 12 and above have two level fill points.
I know Bulky Items wash selection will give you a High water fill which is only 7 inches or so of water in the wash basket. 3.5 inches of water for a medium fill.
You can turn on/open the water inlet valves in Service Mode but I would not recommend that. A manual fill as you did is the only safe way to set the additional water level IMOP.
FAV6800A/FAV9800A Service Manual for reference.
Rich
Jul 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Sometimes the machine just fills up with water, doesnt spin but continues to fill up and then leaks it out through the bottom, this happens especially when i try to wash with full load
The FRIGIDAIRE washing machine as in all washers have what is called a WATER LEVEL SWITH. This switch is on the top and this is where you select small,medium or large water levels. This water level switch has a clear hose from the top of swith to the side of the out tub. Please check the following:
1- check that the hose is hooked up on both sides and inspect it that it does not have any holes.
2- There could be a small sock or something foreign in between the inner and out drum therefore clogging up this hole.
3- Replace the water-level swith.
Nov 20, 2009 | Frigidaire FWS833A Top Load Washer
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Water level
The level of water in the drum is controlled by a pressure switch. This switch is attatched to the drum via an air tube which pushes air into the pressure switch as the machine fills with water. There could be a blockage in the pressure chamber attatched to the drum or the pressure switch is faulty.
Oct 31, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washer will not fill
Check your inlet hose from the wall socket, it could be clogged with something. Look also at the machine hose. First turn off the wall hose, and keep a bucket ready.
Sep 07, 2007 | Kenmore 94812 Top Load Stacked Washer /...
It will not fill with water
how do you open top on whirlpool washer?
Jan 23, 2007 | Whirlpool LSR9434PT Top Load Washer
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
