Question about Averatec 3200 Notebook
Manuel break down
Trying to find the way to split the case for this laptop
Http://new.photos.yahoo.com/[email protected]/album/576460762323373557 Picture guide
Posted on Sep 15, 2007
    Scholar:
  • 133 Answers
You can usually open laptops up from the bottom by unscrewing the screws beneath the laptop and lifting the casing gently off. However, some laptop have more than one thing to take off to provide access to the laptop. Some you have to take the keyboard off to get to one part, some you have to take the frame around the top of the laptop. But most common is the botton casing.
Posted on Sep 07, 2007
SOURCE:
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
How to open engine casing to repair fork shift?
Hi,with the engines I have worked on in the past I found that I had to take off the side casings and the clutch housing and the stator,and all the other components first,then the then you can undo all the bolts to split the casing you should get a haynes manuel to help you,its quite strate forwould if you are mechanicaly minded,you nearly have to stripe the engine rite down,a lot of time and patiots is needed,all the best.
May 30, 2015 | Motorcycles
How do I replace transmission breaing in 1998 chev metro 5 speed manual
Pull the transmission, Split the case, pullout the gears and shafts, pull them apart. You need a diagram. Get a bearing kit, replace them all. Also, since your into it, replace the synchronizers also. The gears also need check for pits and wear . This can cause noise and premature break downs.
Mar 07, 2015 | Cars & Trucks
How do you fold down a split rear seat in a 2003 Alero? I bought a used car with no owners manuel. Thanks
if you look in the trunk for a release arm to unlock the seat back so you can fold it down.
May 09, 2011 | Oldsmobile Alero Cars & Trucks
Why are there 360 degree in a circle
360 is more easily mentally divided than 10-based numbers. Once you break 360 down into quarters, you get 90. 90 can be split easily in many ways.
2×45, 3×30, 5×18, 6×15, 10×9, 9×10, 15×6, 18×5, 30×3, 45×2 - 10 ways100 can only be split 7 ways before breaking down into fractions:
2×50, 4×25, 5×20, 10×10, 20×5, 25×4, 50×2 - 7 ways.
Sep 02, 2010 | Computers & Internet
How do i break clutch hub nut n order 2 split transmission casings
can buy the clutch holding tool made by motion pro. that will keep the hub in place while you remove the nut.
May 18, 2010 | Motorcycles
Not able too down shift gears from 3 too 1 on my suzuki bandit 1200 o4 plate
hello had a atv that did this, atv had set for a while, went to ride it, had all gears, went to downshift , to first, stopped then took off again, only had first gear then second no other gears, i tried everything, all different kind of oil additives, they never worked, more than likely, my atv had set for a while and the shifter fork inside the motor had rusted just a little bit, the gear had got stuck , i had to split the motor cases, to fix mine, make sure your shifter isnt stripped out, maybe it needs adjusting, i have seen people tap on the gear shifter sometimes and it would break loose, some atv mechanics, say to ride it, eventually it will come unstuck, or break the case in half to fix shifter fork and gears....
Feb 25, 2010 | 2004 Suzuki GSF 1200 Bandit S
Gateway Laptop it not powering with or battery or plugged in
Try to connect AC/DC power supply to your PC. If it works there is something wrong with your DC Battery. If you have done this, try to use tester to test if the power battery can still transmit power from source. If power is down, may be another kind of battery that is compatible to your PC. Insert only battery required for your laptop that would destroy your PC totally.
Jun 19, 2009 | Gateway Computers & Internet
Split screen pscan lost manuel help pls.
There is a switch in the back I turned off
Jan 25, 2009 | Memorex MVD2022 DVD Player
Averatec 3200 Notebook Logo
43 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
