Question about Kenmore 94812 Top Load Stacked Washer / Dryer
Washer will not fill
The only way to fill washer completly is to hold the water fill level switch on large load.
    President:
  • 1,294 Answers
Check your inlet hose from the wall socket, it could be clogged with something. Look also at the machine hose. First turn off the wall hose, and keep a bucket ready.
Posted on Sep 11, 2007
SOURCE:
GE profile washer wont fill all the way with water. Can only wash 2 pants and 2 shirts and its set on extra large load.
A lid switch doesn't regulate water capacity and if the lid switch fails, the machine will not execute a complete wash cycle. If the washer functions but only at partial water fill for the selected load level... then the problem is likely a clogged pressure switch tube or a malfunctioned pressure switch. Got mine used online - fixed the very same issue.
Mar 19, 2014 | GE Profile WPRE6100G Top Load Washer
After washing 2 loads the machine won't fill to high level it only fills 1/2 way
You have a faulty fill valve. Return/ replace you washer if under warranty. If not then you will have to replace your fill control valve. That valve is where the knob for the fill level is.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Mar 12, 2014 | Danby 1.7 Cu. Ft. 4-Cycle Portable...
Washer will pour water but will not fill up
I see it looks like you have the 3 level water height on the panel. Usually labeled mini, Normal, Large loads. Try selecting Large load.
If that doesn't work, the switch is bad or the fill stop air chamber is not working.
Jun 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Washer will not fill all the way.
you may have to adjust/replace the water level switch. it is located behind the control panel. the water level knob is attached to it. it does have a screw adjustment.
May 15, 2008 | Roper RAB2121KW Top Load Washer
My Maytag Performa PAV 22300AWW washer works eratically at best. The washer keeps filling completely on any water level selection (mini-med-large-oversize) and now the agitator won't work. I'm thinking it...
there is a tube that connects to the water level switch (small med large ) load level, it connects to the outside tub of the washer, inspect it to makes sure that it does not have a hole or crack in it
are you gettting water into the machine woth the power cord unplugged then you have a water valve that is bad , if no water comes into the machine with it unplugged the water valve is ok
if the above two tests are negative then the water pressure switch is bad.
Apr 16, 2008 | Washing Machines
Drum will not fill completely with water
Sounds like you have a water level switch going bad behind the console. Unplug machine, remove console and look behind the dash. You will see a switch that should have a small hose running to it. Gently remove the wires and hose and remove the switch. Be sure that if you replace it yourself, that the hose doesnt become disconnected from the outer basket, and be sure it is rehooked to the switch. Jim
Sep 07, 2007 | Kenmore 94812 Top Load Stacked Washer /...
It will not fill with water
how do you open top on whirlpool washer?
Jan 23, 2007 | Whirlpool LSR9434PT Top Load Washer
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
61 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
