Question about Olympia Startype 3 Typewriter
Olympia Startype 3
This machine seems to start up normally with a return reset to the left side then it lifts the ribbon plate up to the correction position and stops with a constant alarm until turned off. The printwheel does start to rotate slightly and the carraige can be moved freely by hand while the alarm sounds. Nothing is displayed in the LCD at any time.
  • 2 more comments
  • mrclean11 Sep 07, 2007
    I have the ribbon and correction tape out. The carrier moves back and forth freely and does move all the way to the left. Just wondering if it is the lift motor because it is not going back down or the print wheel motor because it's not turning. Any thoughts on that. Also, I'd be interested in a parts source for this machine in case it seems reasonable to order parts. Thanks.
    With help from JoeS on the Smarka typewriter BB I found a broken wire in the harness to the print wheel sensor. Thanks for your help too.
  • karen_ras Nov 14, 2007
    similar situation to Mr. Clean's,, turn power on, carraige returns to the left, beeping starts and does not stop till you power down. No messages shown on the control panel. Could it be the daisy wheel not seated properly? it seems to be floating free,, i don't think that's quite right. ????????
  • JarvisTax Mar 17, 2008
    As soon as my Startype 3 is turned on, a constant alarm sounds until turned off. Carriage moves itself all the way to left and will not function. I see a loose black wire leading to the print wheel section.
    How do I fix or how do I find someone locally to repair? Thank you!
    Problem Solver:
  • 5 Answers
On the left side of the carrier you will find a broken wire inside the bundle of wires. This is usually blue or black and goes to the printwheel motor. You can try resoldering.
Posted on Aug 23, 2012
  • 186 Answers
A couple things to check, lift the cover and make sure there is nothing obstructing the carrier from moving completely to the left. Also make sure your correction tape is not interfering with the print wheel. Try taking both the ribbon and correction tape out and see if the machine will go to ready. If this does not help let me know and we can check a couple other things, But try that first. John
Posted on Sep 07, 2007
  • johnwns
    johnwns Aug 23, 2012
    It has a broken printwheel motor wire which can be seen on the left side of the carrier.
Please identify correct ribbon for Olympia De Luxe Portable
The European models used the DIN spool that has a larger center hole than the U.S. models
DickyO
Jun 06, 2012 | Olympia Office Equipment & Supplies
How do you insert correction ribbon and print cartridge
Go to NADIST.COM, click on current molels, find the Nahajima that id the same as your T/W.
Nakajima made yours.
HAPPY NEW YEAR
DickyO
Dec 30, 2010 | Olympia Startype 3 Typewriter
The correction feature is not working correctly. It attempts to lift the incorrect the symbol/letter, but fails. There seems to be plenty of correction tape and the ribbon seems to be on correctly ......
Be sure that the ribbon and L/O are fresh. If so be sure the L/o is installed with the dull side toward the paper and be sure the ribbons are correctable. (YELLOW OR ORANGE KNOB)
DickyO
Aug 12, 2010 | Olympia Startype 3 Typewriter
Ribbon drive gears are broken . these are two small white gears under the ribbon itself on the right hand side
I can e-mail you a page showing the parts of the ribbon drive mechanism so that you can clarify.... you would then just have to contact a local repair facility for parts.
Provide e-mail if you wish to proceed.
Jan 25, 2010 | Olympia Startype 3 Typewriter
I am looking for a users manual for an Olympia Startype typewriter. Do you know where I can get one?
OLYMPIA STARTYPE 3 is the same machine as the Nakajima AE-740
Go to www.nadist.com and download the Nakajima manual for FREE.
Jan 12, 2010 | Olympia Office Equipment & Supplies
How do you release the left margin on a startype 3 typewriter
If you have lost the manual go to www.nadist.com and download the manual for FREE. They provide manuals for the Nakajima machines so you would want the manual for the AE-740....its the same machine.
Nov 19, 2009 | Olympia Startype 3 Typewriter
Have no manual How do you set the margins on the compact S model
The Startype 3 is the same machine as the Nakajima AE-740.
Jul 28, 2009 | Olympia Startype 3 Typewriter
Operating manual for Olympia Startype
yes I need the operating manual for the Olympia Startype typewriter
Jun 18, 2008 | Olympia Startype 3 Typewriter
Olympia typewriter multi strike ribbon mode
Try code . or , one of them should change the ribbon spacing mode.
DickyO
Feb 26, 2008 | Olympia Startype 3 Typewriter
Does it make a grunting noise? If so, it needs a couple drops of oil on the main support shaft. Also check the indent setting. You need to use the code key to activate or deactivate the indent.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 16, 2007 | Olympia Startype 3 Typewriter
Olympia Startype 3 Typewriter Logo
279 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
