Question about Toshiba M655 VHS VCR
VCR won't play gamecube when hooked up
I only have the vcr and it has no input button on it, and i do not have the original remote, I was trying to hook up my game cube to the vcr so I can play, the game won't show on the t.v. the anteneas and everything are in the right spots and the game cube turns on, they are all on either channel 3 or 4, but still no picture. I am getting frustrated. please help.
  • heavyn06 Sep 07, 2007
    my tv does not have connections for any video game system as it is an older t.v. that i am using, it only has a cable thing in the back.
    Scholar:
  • 133 Answers
You should be hooking the gamecube straight up to the TV, take the VCR out of the equation and try again.
Posted on Sep 07, 2007
  • Ricky Burgin
    Ricky Burgin Sep 07, 2007
    Does your TV have SCART? It's a wide connector with a slight slant to it.
SOURCE:
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
I can not figure out how to put my Toshiba M454 to Line 1 to play my Gamecube.
  1. Run your AV cords from your Game Cube to your VCR input in the back.
  2. Now run the AV inputs from the VCR (outputs) to your TV (inputs)
  3. Now you press "input" on the remote on your VCR to make the VCR play your input thr Game Cube is hooked up to.
  4. Now you set your TV to what ever input you hooked your AV cable from your VCR to.
  5. Turn the Game Cube on and play.
Regards, Tony
May 04, 2011 | Toshiba M454 VCR
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Feb 10, 2011 | Nintendo 64 Console
Have inherited this tv, no manual. Have to use Directv remote. Am trying now to connect new Toshiba vcr/dvr recorder, but TV go on menu to any "input" channel. Does this tv not have an...
Check the tv manual buttons,have a input button.No.Try website like Remotes.com to buy an original remote so can find out with input ur VCR/DVD device unit hook up into like video input like 1 or 2.
Jan 17, 2011 | Sanyo DS27800 27" TV
We purchased a used game cube, they gave me a power cord, and the cord that has the yellow, white and red plugs. When I hook this up the the tv I get the sound and not a picture. Since this is a tv/vcr...
Make sure the yellow wire is plugged in tightly and try pressing the tv/vcr button on your remote. It may say input after you have done that let me know what happens and I will help you the best I can.
Dec 21, 2008 | Nintendo GameCube Console
I have a 1995 nagnavox tv and i cannot figure out how to hook it up to a dvd player. There doesn't seem to be a hook up of any sort. help me?
If you have a VCR you can run the video out from the dvd player to the input of the vcr. then run the vcr coax cable to your tv. You have to set the tv on channel 3 and the vcr to line in. You set the vcr to line in either by scrolling the channel down button below ch 2 (the display will say "LINE") or find the "input" button on the vcr's remote control and scroll through the inputs untill you see your dvd movie playing.
barneyluc
Oct 01, 2008 | Televison & Video
Input
Usaly there is a button on the remote for input but if you do not have that you might try changing chanels below chanel 1. Some Goldstars hide the front input down there
Mar 03, 2008 | Goldstar GVR-DD1 VHS VCR
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Recording from vcr
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Sep 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Toshiba M655 VHS VCR Logo
5,451 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
