Question about Bosch HGS442UC Gas Kitchen Range
Igniters pop about every 10-15 min
When the stove is off the ignitors will pop once every 10-15 min. This stove is brand new, I just hooked it up.
It appear that Bosch stoves are sensitive to the orientation of the hot and neutral. Mine was reversed at the outlet. I changed it to be correct and it fixed the problem
Posted on Sep 07, 2007
Gas oven will not light or open valve, Brand new ignitor
The igniter will not glow unless the gas valve is operational. The gas valve will not open unless there is power to supply the igniter. Igniters have a low resitance (20-100ohm). So, you can test it. Normally there is no power going to the ingniter.
You may have a defective gas valve (usually the safety circuit). The valves are not repairable (it would be dangerous to attempt it, and there are no parts available). So, you must replace the entire unit.
The thermostat may be shorted. If that's the case, the valve thinks the oven has reached temperature, so it doesn't need more heat, so the igniter won't glow, so the gas won't flow.
Jan 20, 2014 | GE Profile JGBP79 Gas Kitchen Range
All igniters stopped working whirlpool 465
I am almost fur sure that the problem will disappear by itself.
The ignitor is a high voltage "transformer". Even with a little moisture, the way to ground for the highvoltage electricity will go via the humidity in stead of the ignition candles.
After a while all will be dry again and all will work nice again.
If not, then there is some trouble with the ignitor or the wire to the ignitor.
I hope this helps, Dik
Feb 15, 2018 | Kitchen Ranges
I how do I replace the ignitor? I had a friend find the problem and now I need to install the ignitor and reassemble the dryer.
There are two common styles of igniters, glow igniters and spark igniters. The igniter ignites the gas either by heating up and glowing, or by sparking. If the igniter fails, the dryer will not heat.
Please check this links to get the instruction for the replacement and the installation though you did not mention which is the brand of the dryer.
Also check the helpful video:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Jul 19, 2011 | Dryers
Electronic igniters won't shut off.
Boy, I had a Thermador that used to drive me bats.
The best solution was to clean around the ignitor pin and make sure the orifices closest to the ignitor are not blocked... It made a big difference.
I used a small fine metal bristle brush.. did the trick.
May 30, 2009 | Bosch 36 in. NGT 935 Gas Cooktop
Frigidaire Stove clock resets to 12:00 when igniters turned on
local contractor came back. Said 6 other people have reported the problem according to Frigidaire.  Wasn't home so I don't know exactly what they did but they claimed to have moved some wires around.  So far no problems.  Electrical engineering friend said that they likely swapped some ground connections around so that when the ignitor draws current it doesn't drop the voltage of the whole system.  Not sure if a homeowner could troubleshoot and solve this one without directions from manufacturer.
Jan 26, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Stove igniters stay on
Hello edmontonDad,
You said, Stove igniters stay on.
The igniter goes off only when the cap is removed.
This is happening with two burners at the same time.
This sounds like a valve control problem!
Do not leave this go.
This can be dangerous!
Seek service right away.
SORRY that it has to be hands on service!
Thank you for using our advice.
Please remember to leave a rating
Oct 03, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
You have water left over from cleaning and it is shorting out the igniters at the knobs, not the burners. I guess the solution is to wait until it dries out unless you can open the top and maybe use a hair dryer.
Sep 21, 2007 | Frigidaire FGF326AS Gas Kitchen Range
Bosch HGS442UC Gas Kitchen Range Logo
255 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
