Question about GE Energy Star WCVH6260F Front Load Washer
GE Model WBSE2090A2WW - shut off intermittenly
My washer stops working intermittenly at different point thoughout the wash cycle. We've had to washer for about 7 years, it's been great. It will stop maybe 4-6 times during any wash. I then have to drain & restart. Any clue as to what might cause this??? Thanks for any help!!!
My ge washer wbse2090a2ww will not spin. It will agitate, fill and drain. When on the spin cycle it sounds like it is working except the tub is not moving. The lid seems to work, when it is on the agitate cycle and I open it it stops, when closed it begins again. Can anyone help?
Posted on Dec 21, 2008
    Scholar:
  • 146 Answers
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Posted on Oct 31, 2007
SOURCE:
GE front load washer shuts off mid cycle
you will need to contact manufacturer to get it repaired
Jan 03, 2013 | GE WCVH6800J 27" Front-Load Washer with...
Gbvh514hww
there is a sensor that will shut it down if it gets to far out of ballance, most of the time it will be making alot of noise and banging sounds when this happens before it shuts down. there are also springs that keep the bucket centered one of these might have broken or come loose
Jul 08, 2012 | GE Washing Machines
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Feb 04, 2009 | GE WBSE2090A Top Load Washer
GE Top Load Washer Shuts off during wash cycle intermittenly
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 22, 2009 | Washing Machines
GE-WBSE2090A2WW
your main control board is bad ( Electronic Timer) if you need one let me know I can sell you one at whole sale but i would need model number to get the right 1
May 22, 2008 | GE WBSE2090A Top Load Washer
Washer Clicks
The main drive motor has a relay switch on the side of it. The clicking and power flicker along with only the first couple of cycles are a good indication if a bad motor relay.
Feb 19, 2008 | GE WBSE2090A Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
545 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
