Question about Mitsubishi WS-65807 65" Rear Projection Television
2 new problems with my TV after my move
I just recently moved my tv from one house to the other. My HD channels don't look as clear as they used to. Also it just started happening the other day, but when I turn on my TV everything is slighlty blurry. After leaving it on for about 30 seconds the picture comes in clear.
  • 133 Answers
Well it may just be the signal in your area that isn't quite as good. That's just fact. Also, because the signal may be weaker, it may take longer for the TV to fine tune to get the best picture quality, which would explain the slight blurring after turning your TV on.
Posted on Sep 07, 2007
Can't access all the channels. I moved tv from one
You didn't say what model number, but check the setup menu to make sure it is set for cable (if you are using cable) and not AIR. Otherwise let me know the model number and what you are using for signal (cable, satellite, etc.)
Jul 04, 2011 | Sharp Televison & Video
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Ive had my vizio for 4 months and just recently the volume on the same 4 channels slowly decreases til you cant hear much. With a change of the channel or a commercial the volume returns. Recently moved to...
First - connect DVD player preferably to the same input (unless you are using RF connector) and make sure that same issue does happens while you are watching movies. If it does - main board in your TV have to be replaced. If it does not - it still cable signal problem.
Aug 11, 2010 | Vizio SV421XVT 42 in. LCD TV
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
May 04, 2009 | LG 42LC2D 42 in. LCD HDTV
When changing channels sporatic static,
Please feed again cable channels in TV by selecting Auto Search / channel preset in TV Menu.
This will update channel data stored in TV memory.
Mar 18, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Channels with auto tuning
The antennas on most TV's are small and so moving the TV to a nee location may have put you in a new place in the house with even less signal. There are TV antenna signal amplifiers you can buy and for $50 or less you should be able to get something half decent that will boost your signal. Are you not getting any channel's now? Because you should still be able to get at least something in the new location. I'm just asking if you're getting any channels in hopes you didn't damage the TV while moving it?
Jan 16, 2018 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Samsung LE26R74BD plasma sreen tv sound problem
To Fix.. The Buzz.. The noise comming from one of the Board Inside. Open it and see..Or call a tech..
Apr 13, 2008 | Sony KP-57WV600 57" Rear Projection...
Mitsubishi HD 65" thin squiggly line in upper right corner that moves
Is the problem there on every source? DVD playback ok?
Suspect signal source  box.
May have bad connection since move.
Is the problem same on every channel,if source is cable direct?
Please provide more info if more help needed....T.
Oct 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
