Question about Teac AG-D9320 Receiver
Teac ag-d9320 5.1 receiver fuse
I put in the new fuse by the power cord and it keeps blowing out. Thank you for your time. Matt R.
    Scholar:
  • 133 Answers
Make sure the fuse you put in matches the power requirement of the device you're installing the fuse into, putting a fuse that does not handle the current will cause this, but do not overshoot as this may fry your device - it must match. If you know it's matched, then the device you're installing the fuse into may be faulty in such a way that it is drawing the wrong amount of power. This can be due to the power supply on the unit.
Posted on Sep 07, 2007
SOURCE:
My teac ag-680 fuse keep blowing everytime i replace it and plug the reciever up
are short in the audio output transistors may have been short since a channel 2 or maybe 4, also open resistance check carefully and change them after you put a 75w bulb in series 100w or where is the fuse clearly, you have to remove the fuse when you put the focus if all is well will turn on only a small incandescent and amplifier work well you put audio speakers and there will, if everything is well put the fuse back and ready.
Jan 14, 2013 | Teac AG-680 Receiver
Teac AG-V3050. Everything looks right but puts out no sound to speakers. Have trien many speakers. Is there a fuse, reset, etc? Thanks
I nce had the relay for the amplifier die on one of my receiver. Basically this will allow the amp to power on and supply voltage to the speakers. Same thing though, i could access all of the menus, adjust setting, and volume but no sound because the amp never clicked on.
Oct 19, 2012 | Teac AG-V3050 Receiver
I just want to know the wattage on the Teac AG-V3050
Teac AG-V3050 and Teac AG-V8050 are very compatiable to help with this question the total watts per channel are 100 watts. Hope this answers or at least helps. Excellent unit, great power to supply great sound for the unit at its time.
Jan 24, 2011 | Teac AG-V3050 Receiver
Teac ag-d9100 center and surround speakers are not working , very very low volume.. the others all work fine. Anybody know where to start troubleshooting. Its not a fuse that I can see , at least that i...
You have to enable them and turn the volume on them up separately with the speaker config, level trim, and up/down select buttons on the remote. You can also adjust the rear speaker delay time or just hit the test tone button and adjust the volume on each speaker separately as it goes through them one at a time...
Jun 01, 2010 | Teac AG-D9100 Receiver
Keeps blowing fuse.
Dissconnect ALL speakers from back of unit then try to turn on.
If it works you have a speaker short.
If not, you have a more serious problem.
DO NOT replace the fuse with anything else but what was specified, as it can cause a fire!
Jun 14, 2009 | Teac AG-V8600
Fuse blows everytime i turn it on
the blue coloured varacter in your power supply circuit needs to be changed
Mar 30, 2009 | Teac AG-V3050 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Dec 26, 2008 | Teac AG-D8900 Receiver
TEAC DIGITAL HOME RECEIVER AGD 8900 AV
I changed the diodos from power supply.
I thought that help you offered
was free,but I forget that nothing here is free.
Thank you anyway
Dec 15, 2008 | Teac AG-D8900 Receiver
Teac AG-D9320 Receiver Logo
289 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
