Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Desktop colour depth change on startup
My desk top changes the colour depth from 32 bit to 8 bit on startup, but only if I log in quite soon. If I leave the logon screen till the logon screen saver comes on and then log in the 32 bit colour stays on. It only happens in my user profile and if I create a new one for testing and log into that instead, everthing is ok. I also get randon no warning shutdowns, or the machine will just freeze solid. 4 seconds of death is the only optin then. It wont complete a virus scan (Various programmes) and also wont have anything to do with compileing and writing DVD`s. = instant freeze or shutdown/restart. Drives are new and file sys passes windows startup chkdsk with no errors. have changed the motherboard/memory/graphic card/tv card. at my wits end.
  • Anonymous Nov 28, 2008
    the graphics on my computer have been messed up every time i try to fix it it says"the color debth on ur desktop is verry low but i dont know what to do
Hi wizard1 I have a problem on start up 32 bit changes to 8 bit i have a 32 xp,can you help thanks.
[email protected]
Posted on Jan 13, 2009
    Scholar:
  • 133 Answers
Your colour issue may be down to incorrectly configured graphics settings, make sure in properties the colour is set to Highest (32-bit). If that fails, you can use a new user account, drag your files over on the new account and re-do your settings and delete your old user account. As you have changed quite a lot of components in your computer, the only likely problem left is either a dodgy power supply unit or an overheating issue. If a power supply detects it has a fault, it will shut itself off. However, go to your BIOS and search through menus for temperature information (you can usually find it in the power section of the BIOS) and check if the temperature is abnormal. Anything like 75 celcius and above can cause the computer to shut itself down as a safety feature. On most motherboards, you can raise this limit so it shuts down at 80 celcius or 90 celcius, or not at all. 80 is the absolute highest I'd ever set a computer at, because the higher the temperature at that sort of level, the lower life expectancy your components will have. You may also have a faulty CPU as "compileing and writing DVD's" is very CPU intensive and can be causing the computer to die. Make sure your CPU is NOT OVERCLOCKED. If it is, take the overclock off.
Posted on Sep 07, 2007
SOURCE:
Band of darker good quality colour at top quarter of screen - below lighter colour and poor quality text
Try having your colour depth at 32 bit, right click on your desktop and goto graphics properties and select 32 bit instead of 16bit
Feb 28, 2011 | Acer Computers & Internet
My computer screen has error message Frequency out of range. This happened when running Google Earth, it changed the color quality from 32 bit to 8 bit. When I tried to change the bit back I get this error...
Right click on the free space in the desktop and select properties. Then go to display properties and change settings to 32 Bit and Change the screen resolution to 1024 by 768 Pixels.
Apr 05, 2010 | Gateway GT5220 PC Desktop
In settings, I want to change from low colour to high clour 32 bit. Because everything is visible in blurred state. Windows XP.
Hi
Thank you for your query
Please do the following
1) Right click on the desktop
2) Left click on properties
3) On Display settings windo that will open up please click on the tab entitled 'settings'
Inside this tab there will be a option to change the colour resolution and colour quality (i.e. 16 bit, 32 bit etc)
If the screen is in a blurred state you may also need to change the screen resolution
I hope this helps.
Mar 01, 2010 | Computers & Internet
Changing my colour on desktop
You'll have to run the game in compatibility mode, with the color depth set to 256 colors.
You do this by right clicking on the executable of your game. click on Properties. Compatibility tab. Click the check to run compatibilty w/ Window 98, and set the color depth to 256 Color. That should work! Happy gaming.
May 30, 2009 | Computers & Internet
Restart at 32 bit depth color
Use System Failure Settings to Stop Automatic Restarts.
1. Click Start and Open the Control Panel
2. Go to System.
3. Select Advanced Tab and then go down to Startup and Recovery.
4. Settings then uncheck the Automatically Restart.
Try that and see if you can sort it out from there. Hope this helps!
May 08, 2009 | Nvidia G-Force FX5200 256M DDR 8X AGP...
On web sites ie ebay for example, I cannot see some of the different colours on the log on page or the blue bars on selling manager. It seems as I am missing some colours somewhere. On the desktop the...
Sounds like your colour settings are wrong. RIGHT click on the desktop and click properties. Click the last tab which is display settings or settings. Check the colour is set to 32 bit as opposed to say 16 bit or 256 colours. If you post specifically what OS you're running, I can probably offer more in depth help if this doesn't suffice.
Dec 14, 2008 | Computers & Internet
Cannot select a lower bit depth in colour than 24 bit?
With better processors and large storage, higher color depth is the order of the day; however if you dont want higher color depth, you can convert the images after scanning. Ofcourse it requires an addl effort.
May 21, 2008 | Canon DR-9080C Path-Through Scanner
DVD playing
Right click on the desktop anywhere there is clear space.
Select Display properties and then select the last tab at the top of the window that pops up.
You should see the slider there to set the resoloution, and to the right is the colour depth.
Nov 17, 2007 | BenQ FP731 17" LCD Monitor
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
394 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
