The recorder will not recognize a disc when inserted for recording. It indicates that a new disc has been inserted and that it needs to be formatted but then it says the disc is damaged and unuseable. I have tried a variety of brand names of DVD+R and DVD+R/W and I get the same results. I can take the same disc and record on it with my DVD writer on my computer. The player plays CD and DVD ok but will not record. - Solution?
-   this is the worst cheapest dvd-r mine worked great for about a month, now freezes up all the time and cant read any disc
dont waste your money on it -   Guest
May 29, 2008
-   Same with me... not only recording problem! now it is not even playing any of the dvd's even the original ones!!!
Any one got a solution? please post here or email me, shankarman@gmail.com-   shankarman
Mar 08, 2008
-   I have the very same problem. Actually it has worked great for months and then all of a sudden it gives me this error message when it is preparing the disc for recording. These are the exact same DVD's I have been using since day one. Memorex DVD+R 4.7GB-   goneinsane
Dec 05, 2007
-   well, simply how do i record from dvd player to dvd recorder-   Guest
The rec mode button does not work at all so the recorder will only record a max of 1 hour as I...
(More)
The rec mode button does not work at all so the recorder will only record a max of 1 hour as I cannot change it from the highest quality setting.
hello, I connected a new oppo BDP83SE via the analog out?s to the analog in?s of my AV receiver, an...
(More)
hello, I connected a new oppo BDP83SE via the analog out?s to the analog in?s of my AV receiver, an audiosignal I can get only from the FL and the FR jack (if connecting the FL or FR out of the BDP to the other in?s of the amplifier I get an audio signal), it means, that the effect outputs of the BDP don?t work or I must change something ?
