Question about Jl Audio 500/1 Car Audio Amplifier
No sound but powers light is green
Aight.. i put speakers in my car(6.5round) and they were sounding good. and i had my 500/1 in there( not hooked up to a sub but all the wires were hooked up in it for some reason) then one day my buddy wanted to hear his subs in my car so i let him listen and t he amp worked fine. then like a week later my speakers cut off and wouldnt work. so i took it to the nearest audio and they said they needed to run new speaker wire to the speakers, then when i finally got my new kicker l7, the amp didnt work, it powers up but no sound from the amp. i just need some help trying to figure what the problem is. thanks
Wat do you mean by....run a test to see if the audio is being sent to the first pre amp in the actual amplifier. Once this is done you can determine if the samplifier is actually the problem. and..... schematic to troubleshoot the device? plz explain
Posted on Sep 12, 2007
    Genius:
  • 1,139 Answers
You need to determine first if sound is getting to the amplifier. Then once you are sure of that you need to run a test to see if the audio is being sent to the first pre amp in the actual amplifier. Once this is done you can determine if the samplifier is actually the problem. If it is you will need a schematic to troubleshoot the device.
Posted on Sep 08, 2007
I have a jl 500/1 amp hooked up in my car and the power light comes on for about 5 seconds then turns off. no sound out of the subs. it is hooked up to a factory deck through a high to low level converter....
hook up the remote wire ( or make sure its hooked up good) check your ground! ground wire not big enough awg wire and put on bare metal not more than 1 foot away from amp. bad ground will cause this.
Sep 12, 2011 | Jl Audio 500/1 Car Audio Amplifier
I dont know how to get my speakers working
The audio cable on the speakers should go into the green audio port on the back or your PC. Once that is plugged in, if you still don't have sound go into your sounds and audio devices in the control panel and make sure the volume is not off or muted.
Mar 25, 2009 | Ozaki DT-500 3-Piece Speaker System...
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Jl 500/1
Sounds like you fried the channel on the amp or your gain might be up to high for the speaker
Oct 26, 2008 | Jl Audio 500/1 Car Audio Amplifier
Sony Xplod 500w green power light no sound
try running the system with a cross-over configuration.
So your left + will be left + and your right + will be in the right + but put the right (-) where the left (-) is and left (-) where the right (-) is. If that doesnt work, then that means that you shorted out your audio out channels. the only way you can fix that is if you have good soldering skills. But other than that I'de say scrap it, unless you have the high outputs and then buy another amp, some mids and highs and connect the mids and highs to the xplod
Feb 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Cambridge soundworks speakers
Happy Holidays Fredonna
Well, easy task, just put a music CD, on system and if you got an headphones, put in the green connector on your sound card, pop up the PC volume, and see if you heard sound, if you do, heard sound then the problem is your speakers. if don't is your sound card.
good luck
Dec 24, 2007 | Gateway Edison Computer Speakers
How do i know where the grren cord goes, there is 2 different green slots and i tryed both of them
Hi, itryed
Well, first thing first! you mean, someone Format your computer? if so. Just see in device manager if the person install the correct drivers for yous specific sound card . (device manager) if not install them from the CD that is drivers for your computer. (sound)
then put the cables and check!
that should do the trick
Nov 19, 2007 | Ozaki DT-500 3-Piece Speaker System...
JL 500/1
It sounds like you have a broken output filter inductor in the amplifier. You should be aware that the speaker outputs of the amp are biased at ~40v DC and can give a good shock if you touch the speaker wire while you're grounded (touching the body of the vehicle).
When you connected the speaker as you did, I would have expected the speaker to move in or out and remain there while the wire was connected to the housing of the amp. I'll assume that the amp was screwed down to the chassis of the vehicle. If it wasn't, you may have more than one problem.
Oct 18, 2007 | Jl Audio 300/4 Car Audio Amplifier
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
101 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
