Hp ipaq 4240
I need help with the wireless concection, my linksys connection is avalable but not connecting. it did connect but it has stopped working. please help. regards sue
  • sdyas Sep 08, 2007
    thank you very much indeed. it worked first time.
    regards sue
  • 133 Answers
Turn your Linksys router off and back on again, then try connecting on your iPaq again. If that fails, do a soft reset on your iPaq and try again. If that fails, do a hard reset. Also, do you have any wireless security set up for the router?
Posted on Sep 07, 2007
I cannot connnect wirelessly with my linksys e1000 router and was told by their experts that my hp pavilion entertainment pc needed an update for the driver of my wireless adapter. I did go to hp website...
Check the following steps to connect wireless linksys router :
First, you have to connect the router to the ADSL or the cable modem.
Your system has to be set in such a way that it will get its TCP/IP network settings from the router via DHCP.
Second, you need to configure the router to use your Internet service.
Connect the antennas to the Linksys wireless router. Connect an Ethernet cable to the Internet port at the back of the Linksys router and it will establish a connection between your modem and router.
Connect another Ethernet cable between the computer and the router. Then connect the router to an electrical outlet.
Dec 04, 2010 | HP Computers & Internet
I cant get wireless on my handheld hp ipaq 2200
change the security settings if any in the wireless router.... use 64bitWEP password for the router and if it is a BELKIN wireless router then WiFi protected setup should be disabled in the roter....
contact router's technical support to do settings in it....
Apr 28, 2010 | HP Computers & Internet
Ipaq hx2700 not playing fair
It may not be an answer but make sure you are using the proper Link G-link and N-link. Also if its a Dlink card make sure when you are installing the drivers from the disk that you DO NOT have the hardware connected, You insert the card after you run the drivers installation disk. Hope this is helpful.
Good luck =)
May 29, 2009 | Linksys Wireless-N WRT150N Router
Hi, my hp ipaq hw6950 won't connect to my wireless router. It endlessly says connecting... connecting... connecting... Thanks
try resetting the router and try connecting check whts the wireless standards in the router and the ipaq and config according to that for instance if ur router can support b then try entering the setting manually it will work try entering the correct wireless key
Nov 01, 2008 | Computers & Internet
If you are using WEP encryption there may be a key you need to enter in order to connect. This will be a long string of letters and numbers. You can find this by looking in the admin of the router under wireless security. I'm sure it's not asking for the admin password or something easy and small. It'll be asking for the wep key.
Jul 07, 2008 | Linksys Wireless-N WRT150N Router
HP iPAQ H4150 Pocket PC
Go to Settings-Connections-Connections-advanced-Network Card.
You will see all available wireless networks in your area. Double click the desired wireless network and tap connect. Note whether the desired network has been connected.
Hope this help,
Jun 26, 2008 | HP iPAQ H4150 Pocket PC
Connecting wirelessly via my laptop
i have a spectrum24 la4137 wireless card.but when i insert into my HP IPAQ H2200.I KEEP GETTING THE does not recognise the network card.-KENNY.
May 15, 2008 | HP iPAQ H2200 Pocket PC
IPAQ h5550
I had to install several updates on my H5550 to get the wireless to work. You need firmware 1.10.10 to start with (the latest version), then there are several wireless firmware updates, and a wireless driver you need to install. I can´t remember what these were off the top of my head, but it might help point you in the right direction.
Oct 30, 2007 | HP iPAQ H5550 Pocket PC
IPAQ wireless connectivity
always start with the simplest answer first so make sure you have WiFi turned on. Think back, have you changed the wireless security on your router? If so you may need to re-enter the network details or add your iPAQ's MAC address to the access control list on the router. In the bottom right-hand corner of the home screen you should have a small HP Wireless symbol, if you tap it you should get your HP Wireless control panel on screen and can 1: turn WiFi on and off, 2: manually enter the WiFi network details and 3: search for WiFi networks in range.
Aug 16, 2007 | HP iPAQ H5555 Pocket PC
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Mar 05, 2007 | HP iPAQ RX3715 Pocket PC
Computers & Internet Logo
420 people viewed this question
David Payne
David Payne
