Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Is there an instruction/users manual
Can my modem also be used as a print server? If yes how do I accomplish this?
  • Normsky Sep 11, 2007
    Thanx Orbixx
  • 133 Answers
You can use a computer as a print server, and the router will allow other computers to connect to it. But other than that, you'll need to buy a print server separately and hook it into your router. You can set your computer up as a print server by installing the printer on the computer and setting up file and printer sharing through the network setup wizard in Windows XP, this can be found in Control Panel. Once that is set up, do the same for all other networked computers and then you will be able to install the printer on all other computers and print wirelessly (or wired) from any computer connected to the router. However, the computer the printer is physically connected to will need to stay on all the time, or at least be on when you need to print from another computer. I'm not quite sure if you can get a router with a built in print server anyway. But you can certainly achieve what you're looking to do - but perhaps not an all in one package like you were asking. I hope this helps you.
Posted on Sep 07, 2007
How do I install the TL-WPS510U on Windows 7 using the Netgear DGN2200 wireless modem/router as the access point? Need detailed instructions.
You can find detailed instructions with pictures and text on how to install this in the quick installation guide found on the manufacture website. Here is a link to it: TL-WPS510U Quick Installation Guide V2
You can also find instructions in the full user guide: TL-WPS510U User Guide V1
And here is the setup wizard for 32bit windows: PSWizard LPR and 64bit windows:PrintServer_Setup_Wizard
The instructions for windows Vista are what you will look at for windows 7.
Regards, Chris
Sep 01, 2011 | TP-LINK TLWPS510U Print Server
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
I bought GT-I6410 from USA, now i'm in Bangladesh, I need Its manula & I can't use this as Internet modem Can I use it as Internet Modem? if Yes, How?
You can download and print the instruction manual in PDF format from Samsung GT-i6410 support website by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Jun 04, 2011 | Samsung Cell Phones
How to change the ip address of a hp jetdirect 170X
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
May 04, 2011 | HP Jetdirect 170x Print Server
When Verizon installed a new a new service I lost computer-printer communication. Do you have updated software to re install the print server again? Thank you for your help
you need to reinstall you print server
following is steps to reinstall print server
1. connect printer to print server with USB cable
2.print server to computer with CAT5 cable
3.put the CD (which you got along with print server) in computer
4.follow instruction step by step
5.It will asked you for IP address, you need to assign IP which is withen the range of your verizon modem(for example
after that it going to work
Feb 12, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 11, 2010 | Linksys WPSM54G Print Server
Motorola SBG900 and Netgear print server
Yes you can , just configure the wireless settings of you SBG900 to the print server and once its done you should be able to make everything working again....
Dec 18, 2009 | Arris SURFboard SBG900 Wireless Router...
Printer Server - Fprgetten Password
If it helps, here is a link to the user manual for that print server. Good Luck!
Jun 15, 2009 | Edimax (PS-3205U) Print Server
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
How can I reset the print server configuration????
Connect a computer to the DLink using a cable. Put in the web browser (internet explorer) and follow instructions at page 15 of the user manual here ( )
Oct 22, 2008 | D-Link Air DP-311P Print Server
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
99 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
