TP-LINK Tenda W311R WirelessN Router AP 4port Switch 150Mbps Logo
Juan Nevado Posted on Aug 19, 2013
Tenda 150Mbps Wireless-N Router HTTP 404 NOT FOUND
baha abu soude
Level 1:
Habit-Forming:
New Friend:
  • Contributor 33 Answers
  • Posted on Feb 03, 2014
baha abu soude
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
33
Questions
Helped
15991
Points
37
Http://pcsupport.about.com/od/findbyerrormessage/a/404error.htm
1 Related Answer
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Apr 21, 2011
SOURCE: need help on my TP-LINK TL-WR740N 150Mbps Wireless
Here's a GuessYa. Make sure you have the correct and exact DNS servers. If you screw them up, you'll be able to get cached pages, but new pages or functions will crash. It's a funny thing when you find it for the first time :-)
Carl
How can i set a new password intenda wireless router?
You will need an lan or wlan connection to your router, the service/ip address, 1st, open to your web browser, 2nd, type in your service/ ip address into the link, 3rd, login to your router's settings, and find the wireless setting. if you do not understand these steps, please consult you manual for "login to router" settings, or find the web site, and find user assistance.
Edit username and pasword
http://www.fixya.com/support/r11153882-general_routers_reseting
I cant access the 192,168,2,1
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
3answers
How to remove password from tenda wireless
Push and hold th reset button for 30 seconds or so, the will reset to factory settings. This may help: http://www.tomshardware.com/forum/32272-43-tenda-w311r-installation
Tenda router input eror
It's not the username and password from your ISP. If you try to access your router and you have not changed anything, use the following values:
username = admin
password = admin
Once in the router interface, you will have to configure the router for your DSL-modem (I guess it's DSL since Windstream does not produce cable modems.)
Here fill in the username and password your ISP provided you with.
Let me know if you have any questions.
Wifi connection problems
Wi-Fi connection can create problems for various reasons like incorrect browser settings, errors in cable connection, misplaced passwords or a modem requiring reset.
what problems you are getting???
How to set password in my tenda router
Tenda Router Users face sometimes problems with network issue or etc, we are providing Tenda Router Customer Service Number 1-833-284-2444 Which is the toll-free number for the customer helps. They are available for 24*7 hr. and also provided online service, they have great knowledge in technical.
https://servicenumber.org/tenda-customer-service.html
How to use tenda w311u
Hello there.
You can download manual here and learn how to use it:
http://www.2shared.com/document/uWKtuOXe/Manual.html
All the best,
Steve TM
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
