The Onscreen TV Guide feature no longer works. When I attempt to access it, all that appears is the channel preview window...the rest of the screen is black. Also, I cannot access the TV Guide settings.
Everything else functions normally.
Comments:
Dec 28, 2007
- I have not yet found a solution. LG just tells me to take it to a repair shop, they are useless when it comes to customer support.
-   I have the same problem. LG said I need to schedule a repair.-   riblet14
Jul 01, 2008
-   TV guide with LG says NO LISTING - will not update? How do we remedy this situation.-   Guest
Apr 26, 2008
-   Everything that is being descibed here is what I am dealing with. Comcast says it's LG's problem and LG blames the cable card.-   MattB2
Mar 20, 2008
-   Same problem. I would be happy if there were some way to disable the TV Guide feature.-   Mike_TeeVee
Feb 25, 2008
-   I have the same problem. The initial problem occured when the TV Guide set-up screen appeared asking me which cable operator I used (this is after over two years of it working fine!). I selected the cable company and the screen went black except for the small video in the upper right. My TV comes on to this screen every time I click it on. I have to push the "Exit" button to get back to a normal tv screen. Also, my TV has no idea I have a cable box hooked to it any longer, yet I can use the cable by selecting the correct TV input.
I would like to do a hard reset to return to the original factory settings, but can not find info on how to accomplish that!-   BuckeyeGuru
TVGUIDE caused this problem when they began doing their conversion to digital. I can help you with this. You need the "EPK" file to upgrade the VCHIP. If you email me I can forward you the file and you will have acess to your TV GUIDE functions again it will take a few minutes. You will need an SD memory card to put the file on and put it in your TV..
Email me introspectionx2@yahoo.com
when switching off my tv and i switch back to standby i cannot then get picture or sound. can you...
(More)
when switching off my tv and i switch back to standby i cannot then get picture or sound. can you help please
Hi, i have just bought a QED scart to 3 phono and want to connect from my Lcd tv to my Marantz...
(More)
Hi, i have just bought a QED scart to 3 phono and want to connect from my Lcd tv to my Marantz Amplifier. Ive gone from the Av 1 input from my tv with the scart and the other end with the phono to the amp. The problem i am having is when the input source is selected to tv there is no sound from digital tv only terestrial. And if you switch to AV1 you get sound but no picture, can you help!!
Same problem- no onscreen tv guide that seemed to gradually disappear- 1st the display came up with no available information, then disappeared entirely. Coincided with digital tv upgrades by local cable co.- LG no help, cable co. either. Around same time as others posting here, odd! Get small screen"picture-in-picture" to left hand upper corner of screen when try to access menu. TV no longer under warranty. gail_lash@att.net
