Question about Panasonic CT-27SF12 TV
Switch off Why does my panasonic Tv automatically saitch off without any warning after a period of viewing. Sometimes it is pssible to restart bu generally not for a while.
  • Anonymous Feb 13, 2008
    The sleep timer quit working on my Panasonic Remote Control Part Number: EUR7627Z60, any suggestions on what to do?
    Scholar:
  • 133 Answers
It could be due to build up of heat, check for large quantities of dust that may have gathered and make sure nothing is obstructing the ventalation of the unit. It may well be that it will not turn back on until it has cooled. Failing that, it may be a power supply issue and could quite possibly be a failsafe preventing the power supply from blowing and quite possibly damaging the components of the television, if the TV is expensive, I'd advise against trying to turn it on any further and contacting a professional repairman to inspect the components inside to determine what part is at fault. Also, on an off-chance, make sure the TV does not have an automatic sleep timer set, or some sort of set parental control viewing times set. Some Televisions do have these features.
Posted on Sep 07, 2007
SOURCE:
How do I stop Panasonic TH-49D330Q from going to automatic switch off automnatucally. A warning flashes up on screen to say "TV will be switching off in 60 seconds. Press any key to stop".
hi this is no signal connection if the tv doesn't receive for so long it switches off, power saver, mode thanks, also check sleep timer in the menu thanks
shaun
Mar 09, 2017 | Panasonic Televison & Video
On panasonic viera tx 32 Lx where can I turn off TV speakers sotahat I can play sound through denon sound system
When you plug in to the aux audio jack, that cuts out the speakers automatically. There is no switch.
Jan 11, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
How do I view still digital photos from camera to Panasonic Plasma TV TH-42PV30?
Stick camera memory card into memory card slot on tv. If it does not automatically switch to that input use the remote to change to that input.
Nov 22, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My canon sd10 digital camera lcd balnk/black bu tphoto view in lcd ..lcd like dot.dot.. screen bu photo not show in screen so i donot photo capture
Had the same problem with my SD10. The switch in the AV port sometimes gets dirty or corroded, and tricks the camera into thinking that an AV plug is inserted. This will turn off the screen.
To fix it, repeatedly insert and remove an AV cable into the port several times. This may help break off any corrosion or dirt that may be holding this switch open.
Nov 08, 2009 | Canon PowerShot SD10 / IXUS I Digital...
PT-50LC14 TV SHUTS OFF ON ITS OWN. I REPLACED THE BULB, BU THE PROBLEM PERSISTS. DO I HAVE TO RESET A METER?
After you replacing the lamp, you need to check the fan, if it is workinh otherwise it will automatically shut off due to temp rating.
Jul 26, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Tv just goes blank shoots off then i have to turn it back o n
Using the menu/options button, check whether there is a sleep timer. You may have accidentally set it, and it will shut off the tv at either a particular time, or after a period of time has elapsed.
Jun 30, 2009 | RCA Universal Remote Control
F350 super duty,engine cuts out without warning
Check to see if your truck was recalled for a faulty cam shaft sensor. Some sensors develop hair line cracks which allow contaminants to get in and the sensor becomes intermittent. The symptoms can include sudden shutdown of the engine so a recall was issued.
Jun 25, 2008 | 2000 Ford F350 Super Duty Super Cab
Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Oct 30, 2007 | Sony KLV-S23A10 23 in. LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
