Question about NEC Diamond Pro 930SB 19" CRT Monitor
Mitsubishi diamondpro 930sb flickering
Recently, my monitor has been 'flickering', meaning that there are 'lines' that run up and down the screen, and sometimes more severe white and black lines that look like static, or something. And once in a while, the entire screen diminishes to a 1mm tall bright white line that goes across the screen. Is this a serious, horrible problem with my monitor, or can I get it fixed? I love this thing to death, but I fear it may be on its last legs. Thanks, Andrew
  • Aisengard Sep 07, 2007
    haha thanks guys, I did just buy a 22-inch widescreen LCD.
    I am sad though that my trusty old Diamondpro is dying! Sigh.
I have had the same problem with my 991sb and most recently my 930sb. The first was replaced at NEC's expense however on this second one i'm out of luck. I think its a problem with its power inverter. It may be repairable by a tv repair place. I'll be looking into it and let you guys know.
Posted on Nov 21, 2007
I have the same exact problem. I was thinking it was some distortion from a source i cant detect. Changed the cords switched the Vcard inputs to DVI whatever i did its the same. I got a 17" NEC Multisync Fe700+ standing right besides the 930Pro, It works absolutely fine although i got it from hte basement from junk... pretty sad about this bought it 3yrs ago paid quite a bit... had big hopes for NEc and Sony tube..:(
Posted on Sep 16, 2007
    Problem Solver:
  • 7 Answers
Well if your rich ,junk it and get a new one,sounds like internal problems on board or cord problems broken wires in cord loose pins in pinout plug ,i say replace isnt worth the hassle for repair
Posted on Sep 07, 2007
  • dwolfe55 Sep 07, 2007
    ask yourself this ,how old is it ? that should tell you alot ,there just like people they wear out over a period of time!he he!
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
I need a driver for my monitor Diamond Pro 930SB
Try here, says it's free:
http://www.driverssoftware.com/drivers.php/diamond-pro-930sb-driver/65742
Mar 23, 2011 | NEC-Mitsubishi Computers & Internet
Vertical lines accross the screen
Vertical lines running down the screen is indicative of a data failure to the screen itself, which means either the screen is starting to fail or the data being transmitted through the data cable is being interferred with. Put a hand on either side of the monitor and give the monitor a light twist....does the line disappear? or do more lines appear...in either case, there is a problem where the data cable attaches to the lcd panel itself. You can try to change out cables, if that doesn't correct it, then the panel may have to be replaced. If you have the option of trying the computer on another monitor that would be the first step in seeing where the problem lies.
May 24, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
The screen on my laptop flickers colors and there are lines running through through middle red blue green ect.. it does work on an external monitor tho could this be the lcd inverter
Lines on the screen means the LCD is bad and needs to be replaced. The inverter just makes sure the lcd turns on. That wouldn't cause lines on the screen.
Nov 28, 2009 | Compaq Presario R3000 Notebook
Mitsubishi NEC Diamond PRO 930SB Monitor - cover removal?
Remove the screws as you have done. Looking at the monitor front on you'll see 3 bits sticking down from the top (in the deatil gap) which are clips unclip them by pushing through the corresponding holes along the top. Also there's a clip at each side on the underside of the monitor which are very obvious. With the monitor facing down and everything unclipped just pull the cover upwards. It's not easy but work your way round the front edge and it will come.
Jun 26, 2009 | NEC Mitsubishi Diamond Pro 930SB 19" CRT...
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
Mitsubishi Diamond Pro 930SB limited by Vista
Go to settings and uncheck "hide frequencies my monitor does not support." now go back and see if 120h isn't an option.
Mar 30, 2017 | Mitsubishi Computers & Internet
Ocassional flickering
Not sure what the problem is, but am experiencing the same symptoms every few minutes on a Mitsu Diamond Pro 91TXM, just retrieved from storage after 7 years. How's your screen holding up since April?
Apr 17, 2007 | Mitsubishi Diamond Pro 900U 19" CRT...
NEC Diamond Pro 930SB 19" CRT Monitor Logo
197 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
