Question about Zenith IQB50M90W 50" Rear Projection Television
Remote Control Tried to access menu on the remote but nothing happens when pressing the menu button
  • Rednick Sep 07, 2007
    Thanks troylove11, I'll try your suggestion and get back to you.
    Ok. Menu button on tv doesn't work. on/off, volume, channel up/down, source works, all others don't respond on remote or set. What to do now??
    Genius:
  • 1,153 Answers
Have you tried menu on set? If only remote problem then part# 924-10044. If will not work on set, check to see if everything else works.
Posted on Sep 07, 2007
I accidentally changed the settings on my remote control using the on screen menu from dvd1 to dvd2
I'm not sure the question - perhaps your TV is set to the DVD2 input and it's not a DVD issue.
If so, using your TV remote, push the "input" button until you reach your desired input.
Apr 07, 2015 | Televison & Video
Alba hd tv, no remote and the child lock is on just need to bypass it model no lcd3288ohdf
Okay - this is a secret child lock that Alba puts onto their tvs - not the child lock accessible via the menu which is 0000 as default. Basically there is a childlock built into the handset. Basically if you hold the menu exit button for more than 10 seconds the handset locks - all that happens then is when you press buttons you will see the blue panel flash on the tv but nothing works. This lock happens when the remote falls down the side of the settee or your child gets their hands on it!!! To unlock, find the menu button on the right hand side of the TV panel and hold it for 15 seconds and the menu screen will pop up - Really important you hold for 15 seconds before releasing. Then simply press the menu exit button on the remote and 'hey presto' - you have control of your TV again! Kind Regards, BIG BAD JON !!!
Oct 31, 2010 | Televison & Video
Received new DirecTV HR-21-100 PVR, tried to set up device in remote, now nothing works
Your DirecTV device is probably set on RF (Radio Frequency), which the Harmony can't use. You will need to set it to IR (Infrared) for the Logitech remote to control it.
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
May 20, 2010 | Logitech Harmony 670 LCD Remote Control
We just recently moved and we just got are cable hooked up and the tv now has a parental control on it How do I get it off?
You control access to the Parental Control features with a password. The default password is “0000”. You can
change the password to any four-digit number.
To change the password:
1. Press the MENU button to open the main On-Screen Display
(OSD) Menu.
2. Press the on the remote control three times until the
Parental Controls menu opens.
3. Press button on the remote control to highlight Parent
Lock Enable. The “Key-In Access Code” window opens.
4. Use the number pad to type the default password (0 0 0 0), then
press OK.
5. Press button on the remote control to highlight Access
Code Edit.
6. Press the on the remote control to enter into the submenu.
You will need to use the number pad to type the default pass
word first.
7. Use the number pad to type the new password.
8. Confirm the new password by retyping it.
9. Press the EXIT button on the remote control immediately to exit the OSD menu.
Dec 11, 2009 | Vizio L32 32 in. LCD HDTV
My RCA450 universal remote control does not have a code search button
the rca systemlink 4 remote is very good.it has code search and menue
try also the menue button on the tv itself
Nov 15, 2008 | RCA Universal Remote Control
The menu button on my remote doesn't work
Try replacing batteries. If that doesnt work try aiming directly at Receiver's sensor. If all the other functions work except the menu see if you can access menu directly from the unit itself. If it works then you might need to replace the remote
Oct 13, 2008 | Philips FR975 Receiver
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was...
a) Press SETUP button on the remote control to display the setup
screen
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
change the region code
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR
1.press eject to open the draw.
2.type 9-8-1-7.
3.press select to go through regions.
4.change to region 9 for multi region.
5.press eject to close the draw.
OR
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Hack
With no disk loaded: Press the Menu button on your remote control
Press the 5 button on your remote control
Press the 7 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control The currently selected region will be indicated on the onscreen display Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback Press the Menu button on your remote control
Press the Menu button on your remote control tried this a couple of times but got no joy, but then on my third attempt I pressed the open/close button on the remote by accident instead of pressing Menu twice & hey presto my sr150m is now multiregion!! Give it a go
Jan 01, 2008 | Televison & Video
Zenith IQB50M90W 50" Rear Projection Television Logo
42 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
