Tv There is no sound coming out from the tv,and theres nothing but snow on the screen,but when my son plays hi x box there is a picture and there is sound,what is the problem?
  • 398 Answers
Although you did not mention what the make, model number or type of TV it is, I will assume that you are using a cable or satellite box, and the most common reason for what you are seeing is the TV is on the wrong channel. Using the TV's remote, make sure the TV is on channel 3. Most of the time that is all you need to do.
Posted on Sep 07, 2007
2 Suggested Answers
SOURCE:
  • 458 Answers
SOURCE: "snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Posted on Aug 24, 2009
Vizio 48 flat screen has sound, picture will not come on right away
What cable is being used? Often times there is a few things that could effect the picture and causing flicker. If you are using an HDMI cable, or the hdmi plug on the box or tv, you could have that problem. Because the picture is digital, you don't get the snow and lines we were used to. Because the cables are so stuff, often over time they can stress and pull on the plug and cable. Try a new cable, if that does not work, try another hdmi input on the tv. If that fails then try a new cable, like a component cable or RCA. If none of these work and you still have this issue with the box then most likely it is the tv or the box. Swap out a new source, and start this process all over again. If you get the same result then it is the tv. If it works with the same cables, then it is your box. Att will send you a new box if that is the case. If it is the tv, call Vizio. Warranty or not call them. If you are sure you are out of warranty, play dumb, be vague but nice. Often you can get someone out there still at no cost.
Oct 18, 2012 | Televison & Video
Our tv comes on but has NOTHING on the screen, it
If your able to hear sound but theres no picture its usually from the fluorescent lamps being broken or the power source that lights them up are broken.
Oct 26, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Aug 24, 2009 | RCA F27442 27" TV
Snowy screen just pops up
Bad tuner in tv....might be possible to solder bad connect in
tuner...........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Sanyo tv # DS35580
you need a new tuner
Dec 04, 2007 | Televison & Video
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Black menu screen pops and hides half the tv.
that is close caption, get your remote control and press the close caption button.that's it
Oct 31, 2007 | JVC AV-27020 TV
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
No sound no picture.but when playing the x-box picture on and sound
I think your TV is in the A-V mode. The X Box is going into the TV through the A-V jacks. (AUDIO/VIDEO). You should be able to switch the set to tuner mode with the remote. Look for a button labeled input or go into the menu and look for "input". Stargazer
Sep 07, 2007 | Televison & Video
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Ekse
