Fax line setup
I can not receive any faxes. How do I setup the phones lines? It has an ext. port and line port
    Scholar:
  • 133 Answers
Plug the phone line cable into the line port and wait for an incoming call and don't answer the phone, the fax machine should do the rest. Let me know what happens.
Posted on Sep 06, 2007
On the Fax part of the printer do I hook up a telephone line to line in port and Ext out phone port or just line in port to make the Fax work
You would connect the phone line to the LINE connection on the Printer/Fax.
The EXT OUT port would be where you would connect a telephone that uses the same line - for example on a desk nearby, etc.
Sep 16, 2011 | Computers & Internet
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Fax will not work--no dial tone--copier works ok/phone line is ok
Make sure your phone line for the fax is correctly plugged into the Line Port of the printer and not the EXT port. For a more comprehensive guide on how to setup the Lexmark X4270 for faxing, please refer to the Lexmark X4200 Series User's Guide.
The user's guide also contains some fax troubleshooting steps for your reference.
If you still need assistance, please contact Lexmark Technical Support Center.
Aug 24, 2011 | Lexmark X4270 All-in-One Multifunction...
Which port to use for fax???? sonyajohnsonrn@yahoo.com
Followup the steps to setup the printer to send/receive fax.
Connect the phone line ( wire ) to Line 1 Ext at the back of printer port.
The connection is from the Phone socket to printer.
Press the Auto-Answer button on the front panel of the printer to enable automatic fax receiving.
If your no. of rings on voice mail or Answering machine is 4, you need to set 6 Rings to Answer on printer to receive the fax or else the printer will start accepting all the voice mail calls.
Press the Setup button on printer front panel
Scroll till you find Basic Fax settings Or Advanced Fax settings - Press OK
Choose the option Rings to Answer - Press OK
Set the No. of rings. - Press OK
Your printer is ready to send/receive Fax.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 02, 2010 | HP Photosmart C7280 Laser Printer
I'm trying to receive a fax on the 7120 and i'm having a hard time figuring out which chords need to go where. can't find the manual.
Click on the link to download the Manual for your Printer - Click here - Printer Manual
Thank you for contacting FixYa
Dec 02, 2010 | HP OfficeJet 7120 All-In-One Printer
Purchased yesterday HP LaserJet M2727nf. Everything works except it won't receive faxes. Philip Schwartz, Esq.
Make sure the display says Auto or Fax. It should not say Manual.
Also check to make sure your phone line is plugged into the "Line" port and not the EXT or Phone ports. These are the 2 most common issues with not receiving. Especially on new machines.
Aug 12, 2010 | HP Office Equipment & Supplies
Does not recognize phone connection --can not send fax or receive fax--no connection. phone line is direct--works good
Hi. Here are some things you need to check: 1. Check the physical connection. Make sure the phone cable you're using is still in good condition. No obvious defects. 2. There are two phone ports behind the printer- Ext and Line. The phone jack from the wall should be plugged in to the Line port of the printer and not in the Ext. port. 3. Make sure to enter your Fax name and the correct Fax number in the printer. These are the basics on how to setup the printer for faxing. Hope these helps.
Mar 21, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Can't receive a fax but can send one. My machine model number is MFC-9700
There are three different receive modes for your MFC. You may choose the mode that best suits your needs by pressing the receive mode repeatedly until the LCD shows the setting you want to use
if the setup is only for faxing no other telephone lines on the line then select fax only.
if there is a telephone on the same line your gonna want to select Ext.Tel/Tad
if you are wanting to control the phone line and must answer every call yourself by uing a external phone select manual
manual you can use with distinctive ring as well so you can know what is a fax and what is a phone call.
let me know if this works or not please describe your setup if further troubleshooting is needed.
Aug 08, 2008 | Brother Office Equipment & Supplies
Can't receive FAXes
If this is a new fax machine just setup, make sure that the telephone wire from the wall jack in plugged into the rear of the printer in the port named "Line". Not "EXT".
Nov 06, 2007 | Brother MFC-8460N All-In-One Printer
221 people viewed this question
k24674
jasbo
jasbo
