Question about HP LaserJet 4300n Printer
Hp 4300n I can't network to this printer. Help
  • duddy1 Sep 07, 2007
    I printed the configuration page and tried to see if the ip address was on there like its suppose to be, but it was not. I replaced the jet direct 615n and that did not work. what should I check next?
    Printer is connect to the network in my office, I tried a hp laserjet 2200 and it hooks right up to the network.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
1- Let the printer get an IP from the network.
2- print out another config page
3-does it have a printer name? is it there
4-Is the Ip the same as the one on the pc look in printer properties Port and look at what the IP is there and re-enter it manually.
Posted on Oct 11, 2007
    Scholar:
  • 133 Answers
Telling us what you've tried so far might help.
Posted on Sep 06, 2007
  • Ricky Burgin
    Ricky Burgin Sep 07, 2007
    What do you have the printer connected to at the moment?
  • Ricky Burgin
    Make sure the printer doesn't have any manual IP settings and make sure it acquires an IP from your network's concentrator (switch, router) via DHCP.
SOURCE:
Ink flakes off HP color laser jet 1600
whether your printer is a clj1600 or lj4300 the problem lies in the same area- the fixer/fuser unit- this will need replacing - either order a maintenance kit or fuser kit for your machine then follow the packaged instructions to replace the faulty unit
Dec 27, 2013 | HP LaserJet 4300n Printer
4300n hp printer displays a 13.20.00 jam inside rear door.I cleaned everything& I couldnt find any jammed paper so what might be the problem
just carefully check for small pieces of paper inside ot printer,
Look for "lasy" sensor flags etc.
Also remove toner cartridge and check inside for paper.
May 13, 2011 | HP LaserJet 4300n Printer
What's wrong if my test page prints fine, but anything I print off the net has several letters missing on the right side of every line?
your toner cartridge is running low or fuser film is damaged or maybe laser sanner mirrors are dirty.
Usualy toner cartridge is the problem. Try to replace it whit new one firstable.
Jan 11, 2011 | HP LaserJet 4300n Printer
Power on but can not display on control panel
the problem of the 1200 is that it is not picking paper but i have solve the problem thank.
but the 4300n laserjet iks the printer that did not display in the control panel
but i surpect the logic board and the upper board can you tell me your idear about the printer 4300n laserjet am waiting
Jan 07, 2010 | HP LaserJet 1200 Printer
Asterixs on Led display
ram problem pull and reseat ram If still a problem, one of the ram chips faulty Inkypete
Apr 22, 2009 | HP LaserJet 4300n Printer
HP 4300n prints prints larger than it should.
I re-installed the driver. I should have done that first thing.
Mar 25, 2009 | HP LaserJet 4300n Printer
HP 4300n prints off the right margin
You possiblely have a font set wrong in your printer. Push the green check button, arrow down to printing, push the check button again, arrow down to PCL and push the green check button again. Arrow down to Font Source, push check button again and check setting, should be internal. Push the left arrow button till you get back to Font Source and down arrow key to Font Number, all ours are set to 3. Left arrow key back to Font Number and down arrow again to Font Point Size, all of ours are set to 12.00. To get back to ready, uset the left arrow key.
If this is all correct, then it has to be in your software.
Mar 05, 2009 | HP LaserJet 4300n Printer
New LJ 4200N Install
simply connect the rj45 cable and create the printer using hp network printer software. you can download it from the hp website
May 30, 2008 | HP LaserJet 4300n Printer
Networking hp lj4300n printer
This can be setup using HP Jetadmin software (can be downloaded from HP)
May 15, 2008 | HP LaserJet 4300n Printer
HP LaserJet 4300n Printer Logo
51 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
