Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Pink color on projection TV
This the third time my TV has turned pink. I have had a repair person there twice and all that they do is hook up a laptop and reprogram it. There must be more to this problem if this is the third time in 9 months. Any ideas???
  • gsnopy Sep 07, 2007
    Is this the same problem that others are having when it is suggested they replace the light engine?
    I have tried to hold down the menu button as I turn on the TV, but it just gives me the regular menu selection as before. any other ideas how to get into the service menu?
    Sergeant:
  • 279 Answers
Okay, I'll give you the easy fix and the permanent fix here. Easy fix - accomplish what those guys do, without the laptop: Turn off the set. Hold down the Menu/Exit button while you turn it on. Release the button a couple seconds after the set comes on. That brings you into the service menu. Hit menu on the remote for more options. Scroll down to Memory Init. Check the box next to that to clear the pink. Then hit exit on the remote to exit the service menu. I'm still looking up some specifics on the permanent fix - I'll get back to you.
Posted on Sep 07, 2007
  • John Goodman Sep 07, 2007
    Okay, not such good news. This thing is apparently a lemon. You can have the LCD drive replaced, and that will fix the problem... but even that isn't permanent.
    It's just bad design in the LCD drive board. It hasn't been fixed in newer versions of the board, largely because the new board will invariably work until a good while after the warranty period, and then it's not Hitachi's problem anymore. I strongly suggest against putting any more money into this set. Use the above temporary fix whenever it starts getting pink - neither fix is permanent, but that one's free.
    Probably. I'm not entirely familiar with that terminology, but that's likely what they are referring to.
    There have been too many reports of this problem recurring, even after replacing that, for it to be a coincidence however.
SOURCE:
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Samsung HD Television screen turn pink and has no sound.What is that meen?
Sounds like a problem I've seen on many Hitachi dlp sets, But I'll take a shot. First you need to check and make sure the audio/video cables are tight on the back of the tv and the cable box. This is the most common reason for discoloration on this set. Next, you should let the tv cool down and try unplugging the power from the wall outlet. Just about thirty seconds should do. Maybe it will reset.Third thing to try then would be replacement of the color wheel or digital board. I have this set at home and have repaired them for the factory since they were first produced. Most likely it's caused from loose or bad component video cables but if it needs a color wheel it should be obvious upon removal. This requires major disassembly but can be handled by a cautious and alert person with a long handled philips screwdriver. Magnetic preferred. If you need more help I'm here, Russmann.
Dec 01, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Panasonic projection tv
HI, The Pc Board that is located in your set, has become unstable. there are several IC's that control convergence and input streams as well. the damaged board should be replaced asap. it is possible for a service tech to be directed to your home but, most will require you to transport your set to the actual repair shop. i will list the part Number below.
Panasonic Part Number: TNPH0370ADS(PC BOARD) $347.95
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Pink color
Does the tv only look like then when hooked up to the receiver? If it is only then, I would try different cables, If it happens all the time even while not using receiver, then it could be your tint settings on your television.
Feb 04, 2009 | Sony KDS55A2000 55" HDTV
Screen Turns Pink-Mitsubishi 57'' Wd-Y57
since dlps use a color wheel to make the color the color wheel may be going out. get it serviced
Nov 15, 2008 | Mitsubishi WD-Y57 57" Projection HDTV
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
Pink and green colors on screen when first turning on tv lasting 1 hour +
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Jul 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Pink Hue
it must be the problem of convergence in the tv.
for pictures on where is the convergence settings click on this given link.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
but if its the problem in convergence board then check out for this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
May 04, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
PINK AND GREEN COLORS ON BOTTOM OF PROJECTION TV
I'm not really sure on an exact fix for this, but I'm told that these are the symptoms of bad convergence module(s). My set is the same model no. and has the same symptoms. I was looking to see if I could find the exact part no. of the stk ic modules. I'm told that they are approximately $30 to $50 and are not impossible to change out if you have decent soldering skills. The normal repair charge seems to be about $600. Good luck. It looks as tho I may have to just give up and open the back and get the part no.s from the chips
Jan 26, 2008 | Zenith IQB50M90W 50" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
