Question about Canon PIXMA MP160 All-In-One InkJet Printer
E5 errror its telling me unreconisable ink cartridges all of a sudden?one min working next flashing e5 please help...
    Scholar:
  • 133 Answers
As far as I know, you can tell the Canon software to ignore this issue and it will continue to try and print. I can't tell you exactly how, it's just something I overheard from one of my colleagues when he was trying to solve the same problem over the phone. Good luck on finding it - just rummage around the settings with eyes peeled.
Posted on Sep 07, 2007
6ya staff
SOURCE:
I have a Canon MP460 printer and its telling me that it doesn't recognize my ink cartridge. I have even brought new ones but still tells me that it don't recognize ink cartridge. I have cleaned contacts...
U must be using PG40, CL41...
Well.... if you put brand new one, (not the compatible one) and see the same problem... that's something needs to be cared of by A/S center.
However, if you put in the compatible or refilled cartridge (anther one), still u will c the same e5 error.
E5 errror is something can't be solved....
Apr 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
I replaced the color ink cartridge. Now there is an "E" flashing alternately with a "5". The alarm light is on steadily, and the black ink and color ink lights are flashing. How do I...
E5 is a Cartridge cannot be recognized error.
Reinstalling the cartridge could clear the alarm.
If this does not work,
Removed both ink cartridges.
Turn off printer and unplug fron electrical outlet.
Wait at least 5 minutes.
This will let the printer reset itself.
Plug printer back in and turn on.
Printer will cycle and an E5 will appear.
Installed back ink cartridges.
Jan 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Flahing E 5 and lights blinking on black and colored ink
Hi, the E5 means that:
The ink cartridges are
not installed[1401],
or a non-supported ink
cartridge is
installed[1485],
or the ink cartridges are
not installed
properly[1687].
Try with diferrent ink crg., Be sure to use genuine. If that doesnt help, the problem is in printer head, or logic board.
Hope that helped.
Jul 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My HP deskjet F4180 is displaying and E and the lights next the the ink drips are flashing, i have only just put a new colour cartridge in it. do you know whats wrong
It is possible that the installed cartrige may be defective or spurious. please check once again the authenticity of the spare. Otherwise please remove the cartridge and reinstall if this does not solve, try to clean the head using the maintenance button( refer manual)Other wise you can uninstall and reinstall the software as there could be some loading errror.
I hope this helps. Good day
Jul 04, 2010 | Office Equipment & Supplies
My printer layout E5 what should I do.
whats the problem i cant help you if you dont tell me whats wrong
Feb 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
E5 mp145
E5 is "The ink cartridges is not install or a non supported ink"
Probably one from your cartridges is defective.
Sep 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
5E problem
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
1. try to take out colour ink and then put in again to see ok or no
2.try to install new cartridge to see ok or no
3.if this all can't is better you send you printer to authorized canon to check you printer is print head problem or no....
Aug 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E5 error
HI ...
This error comes in when the cartridge is not installed correct ... I would suggest you remove and then re-install the cartridge using the below steps:
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
Please vote if this helps ... Cheers :)
Jul 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma mp190 error code e4
My canon mp190 gives E3 paperjam error but there is no paperjam, how do i fix it?
Jan 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Installed new black and color cartridge.
Are they Canon ink cartridges?
Remove the cartridges, make sure that the tape is removed , and re-install them. Make sure they are seated correctly.
For future reference , these are the error codes for your printer.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
55 people viewed this question
Clive
Clive
old marine
old marine
Ekse
