Question about RCA RP5420 Clock Radio
Alarm how do i set it so the alarms dont go off? Theres 4 positions on the switch, the key one, alarm 1/2, and a like mazda symboled one. If i put it on the key and mazda they both go off and if i put it on the alarm 1 or 2 it doesnt show the current time just the alarm time.
  • 3 Answers
The 'mazda' setting is supposed to look like an analog clock, and that's for setting the time. The key position puts the clock in operating mode, as opposed to clock set or alarm set modes.
I've only had the clock for a day, but if you want the alarms to shut off and alarm again the next day, use the OFF switch on the top right of the unit. If you want to disable the alarms completely, use the 1 and 2 buttons behind the OFF switch to cycle each alarm through the settings: none, bell, music (radio)
Posted on Nov 16, 2007
SOURCE:
1995 blazer disconnected battery now alarm set, going off , no key fob. How do i reset?
that truck dont came whit factory alarm you have an aftermarket alarm unde the dash on the driver side you goint to find a small switch is the valet switch press the switch and turn ignition switch to on position that discobnect the alarm
May 22, 2015 | 1995 Chevrolet Blazer
How to start a proton savvy with no chip in key housing
If not the battery (replacement) then check to make sure the transponder is not missing from the remote. Should be a small plastic to slot in the key. If still not working then you may need to reprogram it. It can only work if you have 2 set of keys to put in the ignition:
[1] Take the key that needs programming put it in the ignition and turn to the on position and then press and hold in the alarm reset button..
[2] While still holding in the reset button turn the ignition off and remove the key..
[3] Re-insert the key and turn the Ignition to the ON position.
[4] Release the alarm reset button and then press it in once..
[5] Now with the ignition still switched on take hold of your SPARE key and press the lock button on your spare key..the alarm should "BEEP" once..
[6] Now press the Lock button on the key that has lost its programming..alarm should "BEEP" again..
[7] Switch ignition off.
Try that it should work
Feb 21, 2013 | Cars & Trucks
How to set time on model HD211B clock radio
1: Remove screw from top back of radio and carefully lift lid that retains buttons. Might be a good idea to take a pic of buttons so they don't get mixed up as they will just pop off at this point.
2: On either side of the back middle button you will see a switch and three (3) buttons.
3: Move "Off On Lock" switch to "Off" (left) position. You will see the unlocked symbol appear on the display.
4: Push far right button first to set your time "Zone" using the "Alarm Time" or "Radio Tune" buttons. Wait 5 seconds for the beep when done.
5: Push the "Time Set" button. (It is the one closest to the "Off On Lock" switch).
6: Use the "Alarm Time" or "Radio Tune" buttons to set the time. (Note: "PM" will appear in the upper left corner of the front display when your time is after noon!)
7: The time display will stop blinking and set about 8 seconds after your last move.
8: Push "Calen" button to set calendar. First the year the push the button again to scroll to the date.
9: Push the lock switch to the right and the lock symbol should disappear from the front display.
10: p
If you removed any buttons put them back, then put the cover back on and re install the screw.
or
Call the front desk and ask them to set or replace the clock.....
Oct 17, 2012 | Audio Players & Recorders
Engine won't start. battery just recharged. no sound when starter button pushed. all lights, signals and horn work.
Hi Vegaskeith, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at "BOTH" ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below. Good luck and have nice day. Codes 1130cc com The 1 Harley Davidson Rod Forum
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 08, 2011 | 2008 Harley Davidson VRSCD Night Rod
I have a 1996 3.8 liter camaro. I was driving my car down the road when the gages started jumping and i found out that problem it was the battery and aldernater well after i changed them problems i have...
Hmmm, a puzzle.
The only way to disarm these alarms is with
the factory remote or turning on the ignition.
To turn off the factory alarm.
Ok, do you have the remotes?
If so, let's ID the system.
Go to www.KEYLESSRIDE.com & use th fcc #s
on the back of it.
If not try this:
Programming Factory Security on GM Cars and Trucks
Instructions for programming the GM factory security systems that do NOT
disarm from the driver's door key cylinder. This programming is for the
cars and trucks listed below.
96+ Camaro
96+ Firebird
99+ GM Trucks
99+ GM Sport Utility Vehicles
Step #1 Turn the ignition on then off.
Step #2 Remove the radio fuse only (not the fuse that says acc/radio).
Step #3 Turn the key to the accessory position. When you do this you
will get two chirps from the door buzzer. Should you hear only
one chirp, your vehicle does not have factory security and these
instructions do not apply. You need to hear two chirps.
Step #4 Press the unlock switch on the door. This will give 1-4 chirps
depending on the program step. Continue pressing the unlock
switch until you get to the desired chirp setting.
1 Chirp - Security off
2 Chirps - Remote Only
3 Chirps - Factory Setting
4 Chirps - Passive Arming
Step #5 Turn the ignition off.
Step #6 Put radio fuse back in.
Jul 03, 2011 | 1996 Chevrolet Camaro
Have a 97 sportster that wont start just strong click, put in new battery, new ground cable, new positive cable, took green wire off starter jumped it to top and starter spins, could solenoid be shot?
Hi Mikegibso792, and the usual suspects are:
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
For a prime suspect please visit website below and good Luck.
Jun 24, 2011 | 1993 Harley Davidson XLH Sportster 883
Have a code alarm for car remote dont work and cant disable it. wont start how do i disconect alarm so car will start
Provided that your system is not programmed for coded override, the standard emergency override is as follows:
1. Enter the vehicle (the security system will trigger.)
2. Locate but do not press the valet/override switch yet (it should be a small black button installed under the dash within reach of the driver)
3. Turn the ignition key to the ON position.
4. Press and release the emergency override button (The security system will turn off).
Note: If the automatic arming feature is enabled on your system. The security system will re-arm the next time the ignition key is turn off and the vehicle's doors are closed.
If the coded override feature was enabled by the installing dealer, you will need to follow these procedure:
1. Enter the vehicle (the security system will trigger).
3. Turn the ignition switch to the ON position.
4. Within 5 seconds press the emergency override button the number of times corresponding to the first digit of your personal code (Default digit is 1).
5. Within 5 seconds turn the ignition key OFF, then ON.
6. Within 5 seconds press the emergency override button the number of times corresponding to the second digit of your personal code (Default digit is 1).
7. Within 5 seconds turn the ignition key OFF, then ON.
8. If entered correctly the security system will turn off.
9. Turn the ignition key to the OFF position.
If the coded override feature is enabled and the code is lost, the system will need to be reprogrammed by an authorized dealer.
Aug 03, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I replaced battery in my audi 80 2.0 tdi but have lost the remote and alarm wont stop going off .
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction: Alarm LED in rear fog lamp switch illuminates for 30 seconds when vehicle is locked.
How
NOTE: A maximum of 4 keys can be programmed (one at a time).
As memory positions of existing keys are unlikely to be known: Obtain and reprogram all keys.
NOTE: Existing key memory positions will be overwritten.
Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Using first key, press unlock button once (programs memory position 1). Alarm horn sounds once to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF. To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key: Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Press unlock button at 1 second intervals, as follows: Twice for memory position 2 (second key). Three times for memory position 3 (third key). Four times for memory position 4 (fourth key). Alarm horn sounds once every time unlock button is pressed, to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF.
NOTE: Ignition MUST be switched OFF between each key programming procedure
Jan 10, 2010 | 1992 Audi 80
Program remote control for mazda mpv 2002
Courtesy of: forums.mazdaworld.org
Try this, it works on several 2002 models:
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done
Dec 06, 2008 | 2000 Mazda MPV
Horn blows,lights flash,car will not start
HI...
you have activated the ANTI THEFT SYSTEM.
If you have the original key.
you can try desactivate unlocking the trunk.
or unlocking the driver door.
ALL of this if you DON'T have AFTERMARKET alarm.
if you have aftermarket alarm.
1- Put the driver window down.
2- Put the key on switch, run position.
3- leave the key in the switch.
4- Disconnect the battery at least 1 minute.
5- connect the battery and try to start the car.
The positive terminal is located a right front of the strut towel.
I hope this can be useful in your problem.
THank's for use fixya.
Jul 25, 2008 | Chrysler Concorde Cars & Trucks
RCA RP5420 Clock Radio Logo
857 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
