Question about Hitachi 46BX01B 46" Rear Projection Television
Hitachi Big Screen TV 46 inch Problem
I recently turned on my television and there are blue and yellow shadows on the right side of all the images. What is wrong?
  • Anonymous Jan 20, 2009
    I was told that the 2 chips that sync the color need to be replaced, since I have red and blue shadows, and the automatic sync button does not clear it up. Can I purchase and install these myself? or is it something that it needs to go to a shop to be repaired?
    Stan
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and Hitachi Big Screen TV 46 inch Problem - 2c07611.pngeplaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
    Genius:
  • 1,153 Answers
Convergence could be going out. Is color misaligned on right side? Or is the pic clear with shadows?
Posted on Sep 07, 2007
SOURCE:
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
Blue shadow
No. I would suspect it being a Optical Block issue. I is not a pretty repair not to mention the cost factor. If you could get in touch with Hitachi Customer Service they could lead you to s service facility that could comfirm what I think.
Jun 22, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
46 inch hitache projection tv
sounds like the bulb has gone, go to your local tv store and the should be able to get you a replacement.
Mar 10, 2009 | Hitachi 43FDX01B TV
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 46F500
Having yellow and blue shadows outlines show up on picture.
Oct 03, 2008 | Hitachi 46F500 46" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Convergence Problem
Convergence problems, you would need to replace convergence amps and look for any return resistors to replace. The big STK's-*** are the amps.
Sep 14, 2007 | Hitachi 46BX01B 46" Rear Projection...
Hitachi 46BX01B 46" Rear Projection Television Logo
1,547 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
