Hotpoint wma10 washing machine wont stop filling up
This model of washing machine when starting up will not stop filling up .tried different programmes .it has just started doing it today .have to stopit and spin to drain it. there was that much water today that it started coming through the door.sometimes it will have that much water in it and turn and fill up and will fault and stop running in a matter of 2 minutes or so
  • 240 Answers
You may have a problem with the pressure dome hose (has a cut or kink in it) or it may be a problem with the main control board. Sometimes that small hose inside the machine can get a cut or come loose. That sends pressure to the board and its valve to let the machine know that it has the right amount of water in it. If it has a hole or is blocked, that signal wont ever come on, and you have overfilling.
Posted on Sep 07, 2007
Hotpoint wont fill properly
what is your model number is then we can get started then
Jan 22, 2013 | Washing Machines
Hotpoint first edition WMA10 making a bangin noise during wash programme. Cannot find filter in order to clean. trishisfit2000@yahoo.co.uk
I have the same model at work only under the frigidaire branding. The shock mounts for the
drum are made of plastic and can break (especially if the unit is moved without the
shipping screws) If one breaks the unit will make a clunking sound.
Dec 06, 2010 | Hotpoint First Edition WMA12 Front Load...
Hotpoint topload washing machine won't water won't stop running.
washer top load will not stop filling even when turned off
Dec 01, 2008 | Hotpoint VBSR3100D Top Load Washer
Hotpoint washing machine model WMA10
the filter is on the front bottom left or right. if this helps please rate joe
Nov 21, 2008 | Hotpoint First Edition WMA12 Front Load...
NOT FILLING PROPERLY
have you got the drain pipe going up to about worktop level of machine?
if the drain just goes downwards then the water just runs out as fast as it comes in. get a sililiar situation if you put drain pipe too far down a standpipe - then a syspon forms and water drains out
Jun 28, 2008 | Hotpoint First Edition FEW12 Front Load...
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
WMA10 abridged programme cycle
is the drum going round at all if not then most likely your carbon brushes which puts power to the motor there is 2 either side of the motor you will need some bent nosed pliers to take them out must have at least 8ml of carbon on them
Sep 26, 2006 | Hotpoint First Edition WMA12 Front Load...
Washing Machines Logo
620 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
